Author Topic: What is a tying joint?  (Read 631 times)
Offline WoodenNickel
« on: April 03, 2018, 01:34:52 PM »
I'm trying to learn about timber framing and I've seen lots of references to tying joints - but no clear example or definition.  Does somebody have one?  Or is it just a joint that ties things together?
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: What is a tying joint?
« Reply #1 on: April 03, 2018, 01:37:18 PM »
Basically yes. We use a tying joint to hold the bents together in the middle of the floor system. So it is on the end of a joist and it is called a tying joist.
Sometime they are in between sills to hold the sills from spreading.
Jim Rogers
Offline Roger Nair
« Reply #2 on: April 03, 2018, 01:56:14 PM »
WN, I would broadly define a tying joint as a joint under tension, which can show up in different cases such as lower truss chords, truss king and queen posts, ceiling joist, some collar ties, hammer beams, cables (you can't push on a rope), scarfs and some braces.  The cases are at different magnitudes and approaches.
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
tying joist joint ?
Started by Hackermatack on Timber Framing/Log construction
Last post June 08, 2018, 07:13:56 AM
by Hackermatack
Cut my first English tying joint
Started by hayton1960 on Timber Framing/Log construction
Last post October 08, 2005, 08:22:28 AM
by Jim_Rogers
Is this a different style English tying joint?
Started by JimXJ2000 on Timber Framing/Log construction
Last post January 31, 2016, 09:37:17 AM
by Jim_Rogers
king post/tying joint?
Started by krusty on Timber Framing/Log construction
Last post July 06, 2009, 04:42:56 PM
by moonhill
