Baltic Abrasives Technologies
Author Topic: Shed Roof 30' Span  (Read 1121 times)
Offline jander3
    • Anderson TimberWorks
Shed Roof 30' Span
« on: April 04, 2018, 06:24:36 PM »
I plan to frame a shed that is 30' x 14'.   Any suggestions on on the best method to cover the 30' distance?    Looks like the mill can'k cut a max of 16-20'.
Is  scarf joint the best approach?
If I run posts every 10', is there a method to connect 10' sections at the post to span the 30'?
Offline Don P
    • Calculator Index
Re: Shed Roof 30' Span
« Reply #1 on: April 04, 2018, 07:23:20 PM »
In mill construction the beams typically are joined on a bolster over the post.
Page 9 here shows some details;
http://awc.org/pdf/codes-standards/publications/wcd/AWC-WCD5-HeavyTimber-ViewOnly-0402.pdf
Offline firefighter ontheside
  • I like trees.
« Reply #2 on: April 17, 2018, 10:43:28 PM »
Use a 6x6 post with a notch cut to let the beam sit on a ledge.  Each beam can sit with about 3 of bearing on the ledge.  Bolt thru each beam thru the rest of the post.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Slant roof span ???
Started by shortlogger on General Board
Last post November 05, 2015, 10:39:29 AM
by shortlogger
T&G Roof Decking On-centre Span
Started by Rougespear on Timber Framing/Log construction
Last post May 24, 2016, 09:04:09 AM
by canopy
sawmill shed... beam span question
Started by sandsawmill14 on Sawmills and Milling
Last post October 18, 2016, 03:01:59 PM
by ChugiakTinkerer
Timber Frame Sawmill Shed span question
Started by alden213 on Timber Framing/Log construction
Last post April 05, 2017, 10:48:32 PM
by scrout
