Author Topic: red oak for barn sills?  (Read 925 times)
Offline thermos
« on: April 11, 2018, 02:15:14 PM »
spring greetings from the rolling hills of northeast missouri ~
we ordered a bunch of 8x8 white oak (they'd be bottom sill timbers for a timber framed barn) from a local mill and what they actually milled up is half white and half red oak timbers. i couldn't tell you why they did that :)
question is: do i reject the red oak for bottom sills or could they be an serviceable choice?
i want them to work because we're ready for them and the quality is fine, but i'm concerned that the red oak would be a bad choice for rot reasons. foundation is concrete piers, all tops 1' above grade. there will be deep livestock litter in the barn at times. the rest of the frame will be doug fir.
any insight from this knowledgeable group would be most appreciated! ~ thermos
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: red oak for barn sills?
« Reply #1 on: April 11, 2018, 04:09:18 PM »
I sure wouldn't use redoak for a sill.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #2 on: April 11, 2018, 05:39:18 PM »
x2 white oak is the one.
Offline thermos
« Reply #3 on: April 12, 2018, 09:36:38 AM »
alright thanks..white oak it will be!
Offline Brad_bb
    • My timberframe blog
« Reply #4 on: April 12, 2018, 01:10:52 PM »
x3
Offline Roger Nair
« Reply #5 on: April 12, 2018, 01:51:43 PM »
I would shift the design more towards an earthen floor rather than have a suspended wood floor, with a heavy manure load, just above the ground level.  Could be a cost saver and would mitigate the risk of nutrient accelerated decay in the floor system.
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
Do you need sills?
Started by ballen on Timber Framing/Log construction
Last post November 09, 2010, 08:29:37 AM
by Jim_Rogers
sills
Started by laffs on Timber Framing/Log construction
Last post July 15, 2012, 09:05:40 AM
by Jim_Rogers
TF sills
Started by EastMark on Timber Framing/Log construction
Last post March 04, 2008, 06:17:29 AM
by moonhill
Red Barn, White Barn, Brown Barn, Blue?
Started by kwendt on General Board
Last post March 29, 2015, 03:50:59 PM
by Don_Papenburg
