Baltic Abrasives Technologies
Author Topic: Building with uneven logs  (Read 741 times)
Offline timburbug
  • Member*
  • Love them air logs pilgrim
« on: April 29, 2018, 10:02:24 AM »
I am using 40 ft 14 in white pine.Some are not so straight.Building with green logs.I want to scribe them so they fit tight with except a 1.5 in calk/chink after staining.
Is there a suggestion to manage the curves?
Offline thelogsmith
Re: Building with uneven logs
« Reply #1 on: April 29, 2018, 10:49:39 AM »
depending on how much bow they have you can offset center line. For ex.  you can move it 1/2"(+/- till it looks right) one way or the other @ both ends. This will throw your extensions off though it probably wont be terribly noticeable unless they are bowed bad and you adjust center a lot.  Put the bow in or out, not up or down to keep same chink line. The good thing with logs is you can get away with a lot more than dimensional without it showing.
tk1400, husky 2100's, a 298, 372's a 357 and a token stihl. john deere 317 skid steer. cut it twice and its still to short!
Offline thelogsmith
« Reply #2 on: April 29, 2018, 10:59:40 AM »
Don't forget to account for settling for door/window openings to avoid stuck doors and broken windows. (unless you go non settling then that opens up another can of worms)
Offline LeeB
« Reply #3 on: April 29, 2018, 11:51:50 AM »
You might try posting this in the timber frame/log home section.
Offline jander3
    • Anderson TimberWorks
« Reply #4 on: April 29, 2018, 09:40:21 PM »
Determine volume center with chalk line. Then line up your chalk line marks on log ends to keep the building inline.
If chalk line won't stay on log, then cut the log at window or door opening.  Or, you probably can't use the log.
moved
MOVED: Building with uneven logs
Started by Roxie on Ask The Forester
Last post April 29, 2018, 02:26:42 PM
by Roxie
Last Board Uneven - woodmizer
Started by Woodslabs on Sawmills and Milling
Last post October 20, 2015, 12:55:29 AM
by Brucer
sad
uneven and wavey cuts
Started by John Grange on Sawmills and Milling
Last post December 03, 2015, 04:48:37 PM
by Chuck White
Stacking uneven lengths
Started by snyd1437 on Sawmills and Milling
Last post April 26, 2004, 06:36:19 PM
by Kedwards
