Baltic Abrasives Technologies
Author Topic: Checking joint sides  (Read 1366 times)
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« on: September 26, 2015, 02:28:57 PM »
Yesterday, I traveled to the Hancock Shaker village to visit with some students taking a workshop with Jack Sobon.
I snapped with method he uses to check the sides of a tying joist tenon's mortise in the long sill:
He is using his framing square against the sill (which is rolled on it's outside face, known as the adjacent face) to check with a combination square the sides of the tying joist mortise to see if they are parallel to the reference face surface.
Every time I visit with him I seem to pick up a tip for us all.
Jim Rogers
Offline jimdad07
  • Seeking Information
Re: Checking joint sides
« Reply #1 on: September 26, 2015, 02:43:56 PM »
Seems that man would be well worth getting to know.  I read one of his books and he has a very clear way of explaining things.  You are fortunate to know him.
Hudson HFE 30 Homesteader bandmill w/28' of track
Couple tractors, a bunch of chainsaws and not enough time to use them.
Offline logman
    • M&K Timber Works
« Reply #2 on: September 26, 2015, 02:52:45 PM »
Maybe I'm missing something here but as long as the timber faces are square can't you just use the comb square on the top face to check the mortise for square?
LT40HD, 12' ext, 5105 JD tractor
M&K Timber Works
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #3 on: September 26, 2015, 02:58:16 PM »
Sometimes the faces aren't square but the joints need to be true to the square face. This is how you check a mortise side to a non reference face side.
Jim Rogers
Offline Rait
  • green as green pine
« Reply #4 on: April 11, 2018, 06:20:15 AM »
Hello. I have a question how to check for check for mortise/tenon joint sides if i do not have reference face (using snap line square rule). Timber Framing Fundamentals page 138 shows a jig to hold squares to the snapline but i havent been able to find a place to buy such. All i'v come up is to use stair gauges to fix the squares, (try to) hold both squares to same measurement at snapline (on both sides of timber) and then use combination square like it's shown here. However this seems to be better suited for three hand and 4 eyed persons which i am not, is there a better way to do it?
I am sorry for bumping up an old thread.
Circular saw, chainsaw, drill, non electric hand tools.
Offline klpauba
« Reply #5 on: April 11, 2018, 07:38:18 AM »
I bet two "Squaremate Adjustable Clamp Fixture and Multiple Square Tool" (Amazon title) could do that.  I bought two of these (for $14 ea + shipping) for tenon/mortise checking (but it has many more uses).  There's a video on youtube on how to use it (just search for "squaremate").
Use the squaremate to join the two squares, let them set on the horizontal surface and clamp a piece of wood on either side at the same measure while lining them up with the chalk line.  Then figure out some way to keep it there! :)
Offline ljohnsaw
« Reply #6 on: April 11, 2018, 01:46:54 PM »
No, this is great!  That tip from Jim is great - hadn't seen that before.
John Sawicky
Offline Rait
« Reply #7 on: April 11, 2018, 03:30:26 PM »
My side faces are not parallel (and have curve to them), thats where the tip pointy things from the book woulde come handy - squares could be registrered straight to line and not rely on the face at all.
Offline tburch
  • On a mission to build a Timber Frame woodshop.
« Reply #8 on: April 11, 2018, 03:49:21 PM »
The jig looks like its using trammel points.
Peterson 10" WPF with slabber. Cooks AC36 Diesel.
'94 Ford 4830 Diesel 2WD & FEL.  Norse 450 skid winch.  Logrite fetching arch.  Fransgard Forestry Grapple.
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #9 on: April 11, 2018, 05:38:17 PM »
Could be...
Jim Rogers
Offline klpauba
« Reply #10 on: April 11, 2018, 07:41:53 PM »
Yes, I meant using some wood pointy things instead of the "trammel points" (although @tburch's thought of using them would work even better).
From all sides
Started by AtLast on Forest Education
Last post September 06, 2005, 09:11:32 PM
by pasbuild
what's it good for sides pulp!
Started by pineburr on Sawmills and Milling
Last post May 21, 2002, 08:00:04 PM
by Tom
Adding sides to woodmaster
Started by hackberry jake on General Woodworking
Last post March 14, 2013, 04:47:11 AM
by lynches lumber
Why are the benefits of hewing the sides of logs?
Started by James Klash on Timber Framing/Log construction
Last post September 09, 2013, 06:38:38 AM
by scouter Joe
