Good Or Bad
Started by J_T, September 11, 2005, 10:47:22 PM
J_T
Stoped at a yard sale and spotted a 066 Magnum and a parts saw for 220 bucks has one with 24'' bar and almost new chain need to take choke lever off parts saw and install and should be good to go  ??? Does anyone know what Hp this thing is  ??? Did I do good or bad ???
Jim Holloway
hardwood
sawguy21
That was a real workhorse, and almost as heavy ;D If the compression is good and the bottom end is tight, you got a good deal.
pallis
If you end up with a good running 066 for $220, you should go out celebrate by cutting down some big trees, GREAT BIG trees.  Hope it's a good deal for you.
Al_Smith
Real good price on that saw.This saw seems to have became the standard which all saws are compared to,or so it seems.
J_T
Thanks everyone 8) Fired that thing up today choke is a tad stickey on release but runs great .That rope starting is like getting kicked by a mule :o :D :D
Jim Holloway
fishhuntcutwood
The 66 is a fine saw.  And a good, running 66 for that price is a deal.  You might think about getting an Elastostart for it.  It'll save your knuckles.
MS 200T
MS 361
044
440 Mag
460 Mag
056 MII
660 Mag
J_T
Hey thanks called the saw dealer today and that elasto start is around 20 bucks . Didn't know you could get it as a add on  8) 8) Learn sompthing here every trip 8) 8)
Jim Holloway
DanManofStihl
It is a handle for the pull starter that has a spring in it to make the saw or blower start easier with not as much as a jerk for your hand. They are really handy to have and work really well on the larger displacement engines.
Two Things in life to be proud of a good wife and a good saw.
