clutch or transmission?
Started by treefarmer87, August 17, 2011, 06:57:15 PM
treefarmer87
i was making the last drag today coming down a steep hill in lo 1st and was going to shift to 2nd and pow! something happened. the skidder wont move in any gear. ???
took the transmission cover off and the everything turns fine. the gears are fine too? smvwoody is coming to help tomm. any thoughts?
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Bobus2003
Any resistance when you press the clutch pedal? Could just be a linkage.. Could Broke out the Center of the Clutch disk too.. seen that a few times
treefarmer87
the clutch feels normal, and it shifts normal, it just wont move. i was just researching and the trans. is a NP 435
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
madmari
Must have a hi-lo and reverser box? Is the drive shaft moving to the transfer case? Out of the transfer? Follow the driveline and that will tell you where the break is hopefully.
I know why dogs stick thier head out the car window.
treefarmer87
yep, hi and lo and reverser the shaft moves in and out of the transfer case
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
HuZzEy
does the drive shaft turn from the trans to transfer case in all gears when you try to move it
treefarmer87
no, 2 people at the mill said th middle of the clutch is gone ???
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
madmari
If the shaft is turning out of the transfer case, there is power from the motor to and through the transfer case. If the clutch center let go, there would be no power out of the transmission (the driveshaft would not turn).
  With the transmission in gear and hi-lo in neutral, check if the PTO shaft to the winch is turning. Step on the clutch and the shaft should stop. If the shaft stops, it ain't the clutch.
   The "pop" you heard may have been a gear in the transfer case or even a u-joint.
I just did the clutch on my old TJ- pretty simple set-up. The throwout bearing siezed and went through the pressure plate, acted like no clutch at all- no way to stop power from the motor to the transmission.
  Good luck- hope it's something simple.
lumberjack48
Sounds like the transfer case popped out of low range.
smwwoody
It was the clutch.  I stopped by his job on on my way home and saw a tranny hanging out of the side of the skidder and many pieces of shattered clutch disk laying on the cab floor.
Woody
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
treefarmer87
o yea! the clutch was shattered :)
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
lumberjack48
I spent 30 years around these old TF's never had a clutch shatter, i ran a button clutch disk.
treefarmer87
mine isnt a button clutch, i ordered new clutch and pressure plate, and throwout beaing today ($526), will be here mon.
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Bobus2003
Only ever seen 2 clutches shatter, The clutch in my '06 F350 6.0l Powerstroke shattered, and I had the Disk in a '85 International Dump truck.. Both times we under heavy accel pulling heavy heavy loads
treefarmer87
had a mechanic help put it all back together today, the clutch is right and the flex plate is wrong on it, and on top of that, that is the only clutch made for that model, they can get, the other is discontinued :( then one of the fingers broke on the pressure plate >:( so tomm. its back to the parts store for a replacement.
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
