Arborwear
Author Topic: Batten strips  (Read 2281 times)
Offline Bruno of NH
Batten strips
« on: April 01, 2018, 11:03:11 AM »
I have a good customer that wants me to cut
1x2x12 Pine batten strips
How do you all charge for this?
Thanks Bruno
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline Bandmill Bandit
Re: Batten strips
« Reply #1 on: April 01, 2018, 11:14:36 AM »
I charge by the hour, especially for fiddly work like batten strips.
FYI IMHO 2 inch batten strips are pretty narrow. id make em 3" wide
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4.
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built my self
Offline moodnacreek
  • Sawin by the notches
Re: Batten strips
« Reply #2 on: April 01, 2018, 01:08:19 PM »
I try my best not to saw 1x2 . This is a clay soil area and not much pine and what I do get has large knots so the battens break. So they have to come out of a better grade of pine plus all the extra labor or set up a gang saw. Being such a small operator I have to charge at least 25 per cent [bd. ft.] more for these 1x2 strips.
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Batten strips
« Reply #3 on: April 01, 2018, 01:49:39 PM »
I find cutting 1x2 is they fall apart If your customers want all 8' or 16'. They will get small pieces too.
You can tell the customer to get more lumber, keep the best ones for 1x2 then he can cut them on a table saw later.
 If you keep the best grade and save for batton, maybe.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Batten strips
« Reply #4 on: April 01, 2018, 02:00:40 PM »
   Is he buying the boards from you too? If so how many battens does he want? I would also recommend the 3" battens but I'd would cut what the customer wanted. Is he a new or repeat customer? If he were a repeat customer and caught me in a good mood, which I often am, I might not charge him at all or a token amount. Let's be real - you can stand a lot of 1X6s on edge and cut a bunch of 2-3 inch battens real quick. Also if he really wanted 1X2's it would be a chance to use up any 1X4s I had laying around.
   If he bought the wood elsewhere I'd just charge my normal hourly rate. Worse case if a new customer and he bought from me I might charge half my hourly rate to split them for him.
Offline Bruno of NH
Re: Batten strips
« Reply #5 on: April 01, 2018, 02:09:38 PM »
The customer has been restoring his barn for a few years
He brought me logs and I milled the boards for the project.
He's also my neighbor and a good guy.
He's a linemen and recovering from a Bad fall at work.
    • A&P Saw mill LLC
Re: Batten strips
« Reply #6 on: April 01, 2018, 02:17:43 PM »
.25 a LF
Sawing since 1987
Offline Tin Horse
Re: Batten strips
« Reply #7 on: April 01, 2018, 02:23:51 PM »
As always; you guys just answered another question I had. I'm about to start milling board and batten. Seem to have a lot of interest in it or the past while.  ;D
Bell 1000 Wood Processor. Enercraft 30HTL, Case 580SL. Kioti 7320.
Re: Batten strips
« Reply #8 on: April 01, 2018, 03:10:07 PM »
   Happy b'day Tin Horse.
    I'm assuming these battens will come from the boards you already milled or will be milling from his logs. If so and with info above I would not be charging extra.
    Keep in mind I mill for supplemental retirement income and to occupy my time It is not my main source of income so my attitude is affected accordingly. If income from my milling was my primary livelihood I'd have a different attitude.
    When I sell or mill I always throw something extra in. If I were already milling this guys logs the batten sawing might be the extra I included for him.
Offline curved-wood
Re: Batten strips
« Reply #9 on: April 01, 2018, 03:42:43 PM »
I charge $2/bf + $0.12 extra for milling time ($CAN ). I use some 8/4'' completly clear stuff,  air or kiln dry (not green...warpage), that I put 5 or 6 pieces at vertical and cut to the thickness according to the order.  It make a top product. The thickness may vary from 1/2'' to 1''.  I think 1'' has a look little too much chunky to my taste . Most of the case it is 1/2'' to 3/4''.  Since customers are always looking for a cheaper way to do the job,  I propose a batten of 6'' with a 4'' space between the back boards (same amount of wood ) so a grade with small knots could be used.  If they go to 6'', the price is the same as the rest : $0.70 /sq.ft. for white pine with solid knots.  I have a couple of sheds that are built with 6'' and 4'' batten to give examples so the customer could choose.  The customer like to choose and if they want to bargin I always have the exit door of a cheaper materiel that will do a very good job :). The thickness of the board is 2mm which equals to around 3/4''net. I have a metric + inch double scale on my WM so I could easily switch from one scale to the other according to the grade that the log is giving.  If the customer want thicker stuff the price is ajusted accordingly. ( 2mm=3/4'' for board and batten , 2.5mm= 1'' construction grade, 3mm= 1  1/8''net + a tiny bit more for furniture grade in other words a good 4/4).
Re: Batten strips
« Reply #10 on: April 01, 2018, 03:48:31 PM »
Curvy,
  Shouldn't that be 2cm instead of 2 mm? Lots of us aren't real metric savvy yet and I don't know what is on your mill settings.
Offline curved-wood
Re: Batten strips
« Reply #11 on: April 02, 2018, 04:35:30 PM »
You are wright, I should have written cm instead of mm.
I dont used the metric system for selling wood or in construction. I use it only on the mill because I found it  is easier to remember the mesurement instead of carrying  1/8'' .When I flip the block I have a tendency to forget where I was. Has you could see I dont have  a 4/4  scale (or 6/4, 8/4, etc ). My customers gave the comment that the 4/4 scale is not thick enough for furniture so I go metric. The ruler is sold by Wood Mizer
Offline slider
  • sawyer,trucker,tree service
Re: Batten strips
« Reply #12 on: April 02, 2018, 06:15:06 PM »
I like 2 3/4 x 3/4 for batten depending on how wide the base boards are. My 100 plus year old house came with that and a 30 degree bevel on the batten .It takes time to put that bevel on it with the table saw but it sure looks neat.
al glenn
Offline Don P
    • Calculator Index
Re: Batten strips
« Reply #13 on: April 02, 2018, 08:49:01 PM »
Those do look good.
If you have hemlock available you might get better batten material than pine.
Offline thecfarm
Re: Batten strips
« Reply #14 on: April 02, 2018, 09:19:50 PM »
I made a horse run in,4 inch batten,10 inch boards. I drove by a blacksmith shop that had that on. Took me a year of driving by on the way to work before I saw someone outside,I stopped in and saw it up close and liked it.
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
Re: Batten strips
« Reply #15 on: April 03, 2018, 11:32:40 AM »
I charge .15 for 1x2 and .20 for 1x3 per LF 4/4 all sawed from side lumber of which I have more than I want.
I always include several extra to make up for those that may break.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Re: Batten strips
« Reply #16 on: April 03, 2018, 03:36:09 PM »
When I do board and batten siding, I cut the cants to  9"x what ever max the log will give me, then flip the cant and set the simple set to 15/16 for the boards and cut till I have a 12/4 piece left on the bed.
flip that piece out and do 3 more logs so I have 4 x 12/4 cants to bring in for the battens. Bring those in on edge and set the simple to 5/8 or 11/16 and saw out the battens. I find i have avery little waste this way and the product looks good installed.
I know this will sound weird but according to the little lady one "must" use odd measurements for siding. Even measurement "look chintzy"! SO I cut 9 inch boards and 3 inch battens and people seem to like it that way.
The crazy part is coverage seems to actually work out the best with those measurements.
Offline woodmills1
  • the truth shall set you free
Re: Batten strips
« Reply #17 on: April 05, 2018, 10:44:50 PM »
I cut battens at 1/2 inch thick and 2 to 3 inches wide.  Also I use very nice smaller logs to reduce the breakage.  Therefore I charge 3x what the order was bid and awarded at for the siding.  For example a modified post and beam I did last fall was 50 cents per bd ft for post and beam and any other dimensional, siding was 75 cents and the battens were at a buck and a half with the 1/2 inch thickness counted at 1 inch.  To me the battens end up the most visible so I charge more and use nicer logs.  Do remember that I always give extra pieces of every thing included for free.
Re: Batten strips
« Reply #18 on: April 06, 2018, 10:54:16 AM »
Woodmills I do the same on over run. I shoot for siding jobs to get about 20% to 25% over run for no additional charge.
Offline moodnacreek
Re: Batten strips
« Reply #19 on: April 06, 2018, 12:45:20 PM »
Why is it said that 3" battens are better than 2" ?
Inlay strips
Started by Larry on General Board
Last post November 20, 2004, 01:45:03 PM
by SwampDonkey
Baton Strips
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 21, 2014, 11:11:17 PM
by barbender
Sawing Thin Strips
Started by Ga Mtn Man on Sawmills and Milling
Last post April 28, 2014, 09:58:21 AM
by Cedarman
lotta frigging furrin' strips
Started by 47sawdust on Sawmills and Milling
Last post March 18, 2014, 09:29:06 PM
by backwoods sawyer
