Arborwear
Author Topic: I found this tree today on my property. What do I have?  (Read 4382 times)
Offline scully
  • Orange Mills Matter
Re: I found this tree today on my property. What do I have?
« Reply #20 on: April 06, 2018, 08:49:36 AM »
I would say beach . I think there would be allot of stress in it as well . I would try to 1/4 saw it .
I bleed orange  .
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #21 on: April 06, 2018, 09:29:52 AM »
It's real... No joke. I googled wrinkled bark and found this. Nothing to the extent of what I got but it's out there.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Kbeitz
    • My Hobbies
« Reply #22 on: April 06, 2018, 09:33:19 AM »
If you look real close at what I have there is stress cracks in the bark...
Offline johnnyllama
  • Woodworker, Cabinetmaker
    • Woodmansee Woodwrights
« Reply #23 on: April 06, 2018, 09:53:48 AM »
Can't say for sure, but it look's just like a beech I cut on my property a couple years ago. Got some very pretty curly grain but it isn't the most stable. It dried with a bit of twist but I cut oversized and then ran over jointer before planing.
Turner Bandmill, NH35 tractor, Stihl & Husky misc. saws, Mini-excavator, 24" planer, 8" jointer, tilting shaper, lathe, sliding table saw, widebelt sander, Beautiful hardworking wife, 2 dogs, 2 cats, 23 llamas in training to pull logs!!!
Offline Kbeitz
    • My Hobbies
« Reply #24 on: April 06, 2018, 10:21:35 AM »
We got snow today. As soon as possible I will go back and make a vid of the whole tree. I'm not sure if the winkles go all the way around the tree or not. I'm hoping that it's worth a few  SGU's...
Offline Dozer_Man
« Reply #25 on: April 06, 2018, 10:49:38 AM »
This kinda looks like what we call a Cucumber tree around here. It is a type of magnolia. If it gets huge leaves on it then that is what it is. Bark looks a little different for Beech at least around my parts anyways.
Brady Crabtree
Sawmill Bottom   '15 WM Lt35HD,  WM Pro Sawyer Network, 90 Chevy C50, 04 ram cummins, Stihl 362, 2008 Bobcat T180
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« Reply #26 on: April 06, 2018, 11:06:32 AM »
If it is a beech, you may have a hard time getting anything stable out of it other than small pieces. I'll bet that wood is going to be volatile as it dries, again, assuming it is Beech. It will definitely be interesting to see how it goes!
Offline ljohnsaw
« Reply #27 on: April 06, 2018, 12:21:51 PM »
If so, you would have a life time supply of bowl blanks assuming good figure!
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Kbeitz
    • My Hobbies
« Reply #28 on: April 06, 2018, 12:28:40 PM »
I do know that I will be keeping the slabs at least of one side if the tree. I'm hoping it looks the same with the bark removed.
Offline Babylon519
  • Circle Sawyer
« Reply #29 on: April 06, 2018, 01:44:33 PM »
What direction does the wrinkled side face? In my neck of the woods, the southwest side of dormant hardwoods are sometimes afflicted by the freeze-thaw action when warm sun thaws the bark by day and the freezing temps at night cause splitting in the bark. The flecks in your bark might be an indication of that kind of action over the years. Haven't seen wrinkles like that though!  - Jason
Jason
1960 IH B-275 - same vintage as me!
1960 Circle Sawmill 42"
Stihl MS440 & a half-dozen other saws...
Offline Kbeitz
    • My Hobbies
« Reply #30 on: April 06, 2018, 03:11:06 PM »
I think you nailed it. This was on the southwest side.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #31 on: April 06, 2018, 08:42:47 PM »
I think that it came from the junkyard.
Dremel tree. :D
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #32 on: April 07, 2018, 07:33:39 AM »
It could be Holly?
Holly is evergreen.  The tree in question is deciduous.
Offline opticsguy
« Reply #33 on: April 08, 2018, 11:46:53 AM »
Do you have a mole/gopher problem???
Personally I would wait for the tree to sprout leaves for identification.  No hurry to cut, just one of a thousand trees for you to choose. Best to think and decide the ultimate use, boards or turning blanks or?   I am only guessing but looks like the those "curls" are only on one side.
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Offline Kbeitz
    • My Hobbies
« Reply #34 on: April 08, 2018, 11:58:23 AM »
Yep.  South side only. I will wait until later in the year.  Way to busy now for any new projects.
Offline Rhodemont
  • LT35HD JD4720 Norse 350 Stihl 362
« Reply #35 on: April 10, 2018, 09:33:24 AM »
My beech trees have a similar Shar pei on the southwest side due to freeze/thaw.  Not as distorted as the one Kbeitz found but similar.
Offline forgeblast
« Reply #36 on: April 10, 2018, 01:40:58 PM »
Its beech with beech bark disease.  My beech have it, I need to cut a bunch out to try to save the ones with out.  The bark will crack and have a waxy white look on it, once the secondary infection takes a hold the bark will turn black.
The worse thing is that every shoot that comes up will be infected.  We were told to cut and round up the stump.
Offline ljohnsaw
« Reply #37 on: April 10, 2018, 07:16:11 PM »
K,
Time to make lemonade out of lemons...  Keep an eye on it just in case it is the beech bark disease and cut it before it starts to rot.  Assuming you get some nice figure out of it, promote a new market for "Shar Pei Beech" ;)  Looks to be more rare then Denim Pine! :D
John Sawicky
Offline Kbeitz
    • My Hobbies
« Reply #38 on: April 10, 2018, 07:43:55 PM »
K,
I don't think I have a problem... I cant find another tree like it in all my woods. It must be the last one.
Offline Kbeitz
    • My Hobbies
« Reply #39 on: April 10, 2018, 08:07:27 PM »
When I google beech bark disease all the pictures look like this... Not what I have...
It also says It can be observed on the trunk and limbs of the tree as woolly. I don't see that...
