Council Tool
Author Topic: Sharpening Advice  (Read 3863 times)
Offline Simon3380
Sharpening Advice
« on: April 11, 2018, 12:20:09 AM »
So last fall I purchased a WM BMS 250 and Cooks dual tooth setter. I'm think I'm pretty comfortable with the sharpening part but I just flat out struggle with the setting. It seems like half the time the blades end up cutting a little bit rough like a tooth or two has too much set. I try to straighten them when I see them but it just seems to take forever to get the set just right. I think some of my problem might be trying to revive bands that have hit nails but not sure. It's on my self improvement list to keep track of those blades better. The first question I have is what range do you guys consider acceptable to get a smooth cut, like +/- .001"?
I've read about people and even woodmizer using rollers to flatten the blade/set before reshaping, but I don't see any thing that can be purchased. Seems like Cooks offered something a few years back but don't offer it anymore. Do most people that sharpen their own blades not have issues with setting or do they just make their own rollers?
Sure would be nice to get to the bottom of this. I know now why so many just send there blades out but I'm just the type of person that can't bring myself to paying someone else to do what I can do (even if sometimes it cost me a bunch more at least in the short term. I guess that's why I ended up with a sawmill, and a backhoe, and a skidsteer,  and a ... 😁).
Garbage in, garbage out
Offline ljohnsaw
Re: Sharpening Advice
« Reply #1 on: April 11, 2018, 01:05:11 AM »
I think I saw a few years back that someone made a roller to take most of the set out with a few ball/roller bearings - a pretty simple set up.
Offline Skipper11A
« Reply #2 on: April 11, 2018, 01:10:51 AM »
I resharpen my own blades but I don't worry about the set unless I can see one tooth is way out of alignment.  I correct these with a handheld saw kerf bender tool ( not sure of the name).  I wonder if you're not overthinking this thing.  I cut beautiful wood and actually have people comment on how smooth the cut is, but it's not perfect.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: April 11, 2018, 06:43:12 AM »
I made this "unsetter" or set remover a couple of years ago!  I made it to run my blades through to even the set up before setting them!
I just slide the blade down in between the two rollers and pull it through backwards to eliminate damaging the points!
Doing so really speeds up the setting process!  Now setting "both sides" usually takes less than 10 minutes!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
Basic mechanical skills are all that's required to maintain the Wood-Mizer.
I LOVE MY SAWMILL
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #4 on: April 11, 2018, 07:38:34 AM »
Chuck, you ever notice less tooth life out of your blades? Like teeth breaking off from unsetting and setting?
I am guessing the blades wear out before teeth begin to fail?
Offline slider
  • sawyer,trucker,tree service
« Reply #5 on: April 11, 2018, 07:45:21 AM »
Simon i down set with my cooks setter. Just do one side at a time and by backing the other anvil out. It  takes a minute but it works.
al glenn
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #6 on: April 11, 2018, 09:38:02 AM »
I have the same combination, BMS 250 and Cooks dual tooth. Unlike many, I sharpen then set because I like to set and measure off fully profiled edges not the rounded edges on a dull band.
I also do not like the anvil strategy of the Cooks setter so I reground the anvils to a full bevel and now push and set off the top of the tooth which is where Iím measuring with the dial indicators and is the part of the tooth that leaves the scratches on the board.
Also, Iíve adjusted the anvils so that I get 25 thou set when the gullet of the band is exactly flush with the top of the setter clamps. So my procedure for loading a new band is lay it in the setter, spin the burr off on the inside of the band, put the band in the setter clamps and adjust the gullet to be flush. Then maybe a quarter turn raise or lower to tweak and get to my set value, then start cranking. I donít adjust the tooth set by moving or individually playing with the anvils because if the BMS did itís job all the profiles are very accurate from tooth to tooth and band to band. Once I get the anvils ďbalancedĒ and set correctly, I lock them down with a wrench and move them once in a blue moon, or less.  If the left and right values donít match very closely it means there is probably something wrong with the tooth tip, it got knicked or not fully profiled for some reason.
All three of these steps in combination result is a very quick setting cycle, about 2.5 minutes, and very smooth cut, better than a new band and Resharp.
HobbyHardwoodAlabama.com
Online DDW_OR
« Reply #7 on: April 11, 2018, 10:28:20 AM »
mine is the Timbering sharpener, drag type
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline Chuck White
« Reply #8 on: April 11, 2018, 02:55:08 PM »
No, I haven't, and I think this is my 3rd year using this unsetter!
I don't sharpen "heavy", just so long as the point is there, is all I really care about!
I do get down into the gullet when I can, sometimes that might take the second or third sharpening, and sometimes the profile just doesn't go my way!
~Chuck~
I LOVE MY SAWMILL
Offline JB Griffin
« Reply #9 on: April 11, 2018, 09:32:13 PM »
To the op, we have one of those dual tooth smashers at work and I loathe that thing. .006" consistency is as good as it gets with that thing. I personally have seen it "set" blades to the tune of .010" variance on the same side. And that my friend is why I bought a Suffolk.
P.S. 4x4american posted a video showing why they can't be accurate.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline Simon3380
« Reply #10 on: April 11, 2018, 09:36:16 PM »
Is the gap adjustable? Or do you always have say .045 blades so it doesn't have to be?
Offline tawilson
« Reply #11 on: April 11, 2018, 09:54:13 PM »
Yellowhammer, how do you spin the burr off? My Woodmizer manual says to rub a piece of hardwood around the inside of the blade, but always looking for better ways.
2017 LT40HDG35 WIDE
BMS250 and BMT250 sharpener/setter
Offline gmmills
« Reply #12 on: April 11, 2018, 10:36:56 PM »
Simon3380, You will never be able to hold tight set tolerances with a Cook's dual tooth setter. Just check out 4x4's video. If you want to hold tighter set tolerances and still have the speed of a dual tooth setter you need to look at buying a WM BMT 250 or a Suffolk. Accuracy is fully dependent clamping the deflection out of the blade body prior to bending the teeth. Holding set tolerances of +/ - .001 is what you are after, then a single tooth setter is the only true way to do so.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
« Reply #13 on: April 11, 2018, 10:37:08 PM »
I have a small rectangular piece of carbide stock, about 3/8" x 3/8" x 2 inch long and lightly hold the sharp edge against the inside of the band and hold it stationary while spinning the band in the setter.  The band isn't in the clamps, but being held in the bearings in the arms.  You can feel the burr being shaved off, and only go around once.  There no need to do more because when you get to point you started you can feel the drag lessen significantly which means the burr is shaved off.
A piece of hardened tool steel will also work fine, or anything rectangular with a sharp edge corner that will shave the burr.  I've tried the wooden stick, didn't like it, if anything, it tends to push the burr down, not shave it off.  The setter needs a clean tooth tip to set and measure from.
When I say spin, I mean you can spin the band fast, three of four grab and pulls and it's done. You can also hear the sound change when you come all the way around.
Offline Chuck White
« Reply #14 on: April 12, 2018, 07:03:15 AM »
The gap is adjustable, but not very much, it is set where it was when it was made!
I've set .042 and .045 blade with it regularly!  One time I had a guy bring in a couple of .035 blades and it still worked ok!  If I had to do a .055 blade, it would probably need to be opened up by undoing the bolts and retightening (the bolt holes are ever so slightly oversize).
I mostly do .045 blades, and when the blades are run through the unsetter, they will be between .018 & .020" set!
~Chuck~
I LOVE MY SAWMILL
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #15 on: April 14, 2018, 09:11:45 AM »
My neighbor Tim and i pass the WM "unsetter" back and forth as needed.
YH I dont like the wood method either, so have gone to setting before sharpening.
I dont have the proper cam for the 7 turbos which I an changing over to so use resharp for these.
I am not smart enough to re profile a cam for the 7 turbos.
My sharpener is a 95 drag model.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Chuck White
« Reply #16 on: April 14, 2018, 08:46:22 PM »
I set, then sharpen, and I don't worry about the burr, just pretend that it's not there!
I've never had an issue with it since I started setting first, then sharpening!
~Chuck~
I LOVE MY SAWMILL
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #17 on: April 15, 2018, 12:32:01 AM »
The log will take care of the burr...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline highleadtimber16
  • Learning Everyday
« Reply #18 on: April 15, 2018, 10:22:43 AM »
The guy who used to sharpen my blades, would leave a heavy burr on them. It caused a big rust issue on my Red Cedar boards. I sharpen my own blades now, and make sure the burr and any metal residue is cleaned off.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension, Patrick Model A Loader, 75 Hitachi, Stihl 461, 2X066, & ms 192
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #19 on: April 15, 2018, 05:20:36 PM »
I hate setting..if you get the set within .003Ē youíll make some nice lumber.  I have the cooks dual and single tooth setters.  The single tooth setter is actually quicker if youíre trying to be real accurate because itís easier to tweak the blade.  I pretty much only use the dual tooth to downset teeth because its pretty good at that.
Boy, back in my day..
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #20 on: April 15, 2018, 07:02:10 PM »
I have come to the conclusion that I need to make a set of rollers to remove set. For a setter, I use my Pineywoods inspired shop built setter Link and most of the time, I have no problem unless I hit iron or in some other way damage the band. It is for these damaged bands that I need the rollers.
1992 LT40HD
Offline Bandmill Bandit
« Reply #21 on: September 13, 2018, 08:29:26 PM »
I need some instruction for the sharpening of the carbide bands. I have 6 to sharpen and recieved my CBN wheel to do the job today. Having never sharpened these blades before I would really appreciate any tips and advice there is available to make sure I have a reasonable chance at getting it right on the first shot.
Any one with experience on these blades please post your tips and instruction for me please. Thankyou
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Offline ljohnsaw
« Reply #22 on: September 14, 2018, 12:14:00 AM »
Been a while since this has been up.  I made an Un-Setter from timing belt rollers/tensioners.  I happen to have this 1/2" plate with holes pre-drilled and removable pegs.  The pegs were perfect for the bearing center hole.  Just had to add some washers to lift it off the plate.
Offline Percy
  • Resident trouble maker
« Reply #23 on: September 14, 2018, 12:32:34 AM »
I could be mistaken on this so take it for what its worth...heh... I believe the cbn wheels will do stellite tooth blades as I have done so with great results. The carbide toothed blades that WM sells needs a "special diamond wheel". I have a few carbide ones that Im scared to put on my cbn equipped sharpener as Im scared it will wreck the wheel....
« Reply #24 on: September 14, 2018, 10:48:01 AM »
Yes Percy you are correct on the requirement of a diamond wheel.
Shawn had sent me the CBN wheel for doing the for the regular 7*/39* turbo blades and then sent me an email to let me know NOT to use it and that he would ship me a the correct wheel as soon as he had one in. I got the right one yesterday and the other one goes back today. Now I just need the instructions on how to use correctly.
I was kinda hoping maybe marty would weigh in on the advice part.
How is life up in the beautiful northern interior? I kinda think I may have stopped at your place when I was up that way a couple of years ago but not sure.
Offline Percy
« Reply #25 on: September 14, 2018, 06:33:41 PM »
Life up here is great. Weather is kinda cold....not as bad as you guys but still nipply.
Im still waiting for my molder....since april 14.   Poor Gary and Shaun cant release it till it gets re wired....   >:(
« Reply #26 on: September 25, 2018, 10:48:55 PM »
I sharpened 6 Carbide blades today. What a pleasure! I don't think it took 10 minutes per blade.
Next week will test the sharpening and give more indication of blade life expectancy.
IF I get 3 cycles per blade @ 6MBF per cycle that will be a minimum 60+% reduction in blade cost and an 80% reduction in sharpening time.
It is looking like a 250% to 300% BF increase per sharp cycle. That may be optimistic but that is where the number seem to be pointing right now.
Offline Stephen1
    • muskoka Sawmill
« Reply #27 on: September 26, 2018, 11:36:18 AM »
did you just sharpen? do you have to set these blades also?
LT40HD, 742b Bobcat, Sthil v170,038, 461. 1952 TEA Fergusan Tractor
Offline Percy
« Reply #28 on: September 26, 2018, 08:58:01 PM »
I dont think you are off the mark at all. When I use them carbides for resawing(clean lumber), I get 18-20,000 bdft before I notice anything resembling a dull blade.
« Reply #29 on: September 26, 2018, 10:07:45 PM »
Hi Stephen
Nope no setting required!
I LIKE your assessment too Percy! Based on your comment I am going to push them further.
The ones I sharpened came off at the end of a day or the completion of a job and they were STILL cutting better then a new Bimetal blade. May be there is 10MBF in one sharp cycle on these blades.
Offline Pabene
« Reply #30 on: September 27, 2018, 06:18:57 PM »
I have a drag sharpener and a single point setter. I am convinced the best is to do the set before sharpening. If you are able to give the blades a set accuracy within 0.001", it will cut without scratches on the boards. If you are going to take to heavy cut in your sharpener (or you have a bad undressed wheel) you will have a lot of burr. I think it is good to deburr the blade. If you are going to use a blade with burr on it, I agree the burr will leave the teeth in the kerf and the burr is hardened steel chips. The mix of steel chips and saw dust in the kerf will now dull the blade in the first cut.
Offline Chuck White
« Reply #31 on: September 27, 2018, 08:11:33 PM »
I agree with the first part of your post, but disagree with the rest of it!
I have been setting my blades first, then sharpening for years now and have completely ignored the burr!
Some of the burr will be rubbed off while cutting, but some of it is still there when the blade is ready to be sharpened again!
I set my blades in a margin between .021 & .024 inches and have no issues, and no marks on the lumber being cut!
~Chuck~
I LOVE MY SAWMILL
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #32 on: September 27, 2018, 08:43:45 PM »
I sharpen, then set (or just check the set-if the blade doesnt need setting it doesn't get more set as it goes around), and ignore the burr.
Times I have measured how much burr there is I concluded it wasn't more than about .001 and this is within the margin of setting anyway, no point thinking about it. .
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
advice about sharpening stones
Started by ckprivette on Timber Framing/Log construction
Last post December 02, 2014, 09:42:42 PM
by shinnlinger
Stihl FS550 / Need sharpening advice.
Started by Jasperfield on Forestry and Logging
Last post November 20, 2014, 06:42:41 PM
by SwampDonkey
Need advice sharpening harvester chain 0.404, 0.080 gauge
Started by Jasperfield on Chainsaws
Last post March 08, 2011, 08:51:46 PM
by Jasperfield
Peterson 10" WPF users.....Need sharpening advice
Started by Percy on Sawmills and Milling
Last post December 15, 2008, 11:14:49 PM
by Firebass
