Author Topic: Ireland mill  (Read 1848 times)
Offline NYIrelandMiller
Ireland mill
« on: April 12, 2018, 06:27:33 PM »
Hello all,
 First time posting, long time lurker.   We are a small hobby mill here in upstate ny.   Just curious, how do I tell if I have a left or right hand Ireland mill?   I'll figure out how to post a video in a little bit I'm sure.   Going to mill some basswood, ash and butternut the next couple weeks.
Offline moodnacreek
  • Sawin by the notches
Re: Ireland mill
« Reply #1 on: April 12, 2018, 07:17:22 PM »
Facing the teeth pointing down, if the log goes by to the right it's a r/h mill.  I once wanted an Ireland as the first mill I ever looked at was one. It had the hay rake handles to taper a bunk. This mill was in Mt. Vision, n.y.  There sure was a lot of them in the Catskills and beyond. You can get a reprint catalog. They even had a power set option.     On the general board under I finally found one, in my response I show an Ireland made cant hook.
Re: Ireland mill
« Reply #2 on: April 13, 2018, 12:20:39 PM »
Thanks, my dad thought because the carriage was operated with your left hand it was obviously a left hand mill.   In seeing some pictures that contradicted that, it made me wonder.   Now I know! We have a right hand mill, thanks
Offline Chuck White
  • Sawing Mobile since 2005
Re: Ireland mill
« Reply #3 on: April 13, 2018, 04:49:26 PM »
Welcome to the Forestry Forum, NYIrelandMiller!
~Chuck~
I LOVE MY SAWMILL
Offline Ron Wenrich
Re: Ireland mill
« Reply #4 on: April 13, 2018, 07:29:53 PM »
I ran an Ireland for awhile.  I liked the way those hay rack tapers worked.
Offline moodnacreek
Re: Ireland mill
« Reply #5 on: April 13, 2018, 08:32:57 PM »
There was a picture in timber line of the original Ordy Price sawmill in Pa.  I think it was from the 1920's. It showed the founder sawing an oversize log on an Ireland sawmill the looked like it had the power set.
Re: Ireland mill
« Reply #6 on: April 13, 2018, 09:09:46 PM »
One of these days I will learn all of the proper terminology, and be able to post back here.   Until then we're just gonna send it,   Right handed apparently.    I like to read.   I might print out the copies of the number 8 RH.
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: Ireland mill
« Reply #7 on: April 13, 2018, 09:56:04 PM »
Welcome to the forum NYIerlandMiller!
1992 LT40HD
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
Re: Ireland mill
« Reply #8 on: April 14, 2018, 08:21:33 AM »
Where in NY are you?
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline paul case
  • Original wearer of the PCM.
Re: Ireland mill
« Reply #9 on: April 14, 2018, 08:31:16 AM »
I like this guys mill that happens to be and Ireland.
PC
pc
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
Re: Ireland mill
« Reply #10 on: April 14, 2018, 08:35:18 AM »
Welcome to the FF NYIrelandMiller
couple links first is a little history of Ireland
the second is an excellent circle saw reference
Northern Logger May 2015
https://www.fpl.fs.fed.us/documnts/misc/circsaw.pdf
we like sawmill photos here !!
best
D
Offline Autocar
Re: Ireland mill
« Reply #11 on: April 14, 2018, 08:44:45 AM »
Pulling the feed handle if the log paces on your right side as it feeds into the saw it is a right hand mill and if it passes on your left as it feeds into the saw it is a left hand mill
Bill
Offline Ron Wenrich
Re: Ireland mill
« Reply #12 on: April 14, 2018, 11:45:54 AM »
I always figured if the logs come in on the right hand side of the mill, its a right hand mill.  I've run both.
Offline StimW
Re: Ireland mill
« Reply #13 on: April 14, 2018, 11:06:55 PM »
How do you know when an Irish Honeymoon is over?
When Peter goes to Dublin!    :)
New HF Band Mill
Branson 35 hp 4 WD Diesel Tractor W/Attachments- Backhoe, FEL W/ Bucket or Forks, 4' Tiller
4000# Clark Forklift W/24" Tires
Promark 6" Brush chipper W/18 hp Kohler
Re: Ireland mill
« Reply #14 on: April 15, 2018, 01:43:55 PM »
Thanks for all the info folks.   I just read the 93 page circle saw bible a member sent me.   I will also check out those links.   We do have a right hand number 8 (pretty sure it's not a 6) mill.    Bear swamp-   I can almost see bearswamp from my house, I am two hills east in Tully (Otisco).
Regarding the YouTube video of cutting ties,   I've seen a few videos of guys dropping only one dog on the head blocks and a video of not even dropping any dogs on the log.    That would make me nervous, but would save time.    We usually have one guy running the carriage (and first dog), one guy running 2-4 dogs, and one guy tailing the saw.   Powered by a pto 135-175 horse tractor sitting outside.
Offline moodnacreek
Re: Ireland mill
« Reply #15 on: April 15, 2018, 03:19:13 PM »
Man your not hurtin for power.  When the log is heavy, on a flat side, no ice or snow, no dog.
Re: Ireland mill
« Reply #16 on: April 15, 2018, 03:19:41 PM »
Looked like the guy was only setting 1 dog and he had no hearing or eye protection.
He will be as hard of hearing as me when he gets older maybe blind too.
I sometimes dont clamp the cant until I am sawing thru and thru.
I only watched 8 mins of the vid then got bored.
LT40SHDD51
Kubota 900 RTV
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: Ireland mill
« Reply #17 on: April 15, 2018, 05:38:49 PM »
Next time Im out that way Id love to stop in and check your setup out I have friends in Tully, LaFayette, Otisco, Fabius, DeRuyter, Cortland, Etc etc
Boy, back in my day..
Re: Ireland mill
« Reply #18 on: April 16, 2018, 10:23:22 AM »
4x4- anytime I like to show it off.   Grandpa bought it in 1952 from Jamesville where they made ties for the railroad by rt 481.   We are a dairy farm, and grandpa and the dad and uncles built a few barns back in the day from the mill.   We mill only a couple weeks out of the year, and sell a little (mostly stockpile) on Craigslist Facebook word of mouth etc.   Mostly the ash that is dying the last few years, but some butternut, walnut, cottonwood, tulip poplar, spruce a couple locust, and one cherry log.   Basswood soon once my uncle gets the sawdust truck running.    He configured a silage blower to blow it onto a truck outside.    Might get a couple yards of sawdust at best in a day.    I would rather mill today and not worry about the sawdust, but waste not want not seems to be a common saying with low milk prices.   We only mill from Our own woods as we are very paranoid about hardware.   I like to make large dimensional lumber as I get bored of making boards.  Trying to get my friend to send some past videos so I can post them.
Offline moodnacreek
Re: Ireland mill
« Reply #19 on: April 16, 2018, 12:25:26 PM »
N.Y. Ireland Mill, There has got to be very few people left that milk cows and saw lumber. I enjoy reading your posts and knowing you are out there working your land.
Ireland Shingle Mill
Started by Carleton on Sawmills and Milling
Last post July 23, 2012, 06:42:44 PM
by loggah
CBN wheel from Ireland.
Started by petefrom bearswamp on Sawmills and Milling
Last post December 17, 2012, 09:26:45 PM
by customsawyer
cell phone in Ireland
Started by simonmeridew on General Board
Last post September 01, 2008, 10:01:10 PM
by Lurcherman
Help with a Post&Beam shed in Ireland
Started by darken9 on Timber Framing/Log construction
Last post August 18, 2014, 11:10:37 AM
by Dave Shepard
