TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Lubmizer Nozzel Issue  (Read 1227 times)
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« on: April 13, 2018, 08:16:57 AM »
What's the deal with removing and reinstalling the top Lubmizer spray nozzel?   I don't ever remember ever having a problem with this in the past.
I went out and fired up the mill for the first time in about 2 months and both lubmizer spray nozzels were clogged.   The bottom nozzel screwed right out and back in after unclogging with no problems.   The top was a completely different scenerio.  First when I screwed it out it pushed against the blade guide roller but finally wiggled free.   However, there was no way it was going back in with the roller in the way.   It looked as though the nozzel itself was too long.   I WAS NOT GOING TO REMOVE THE BLADE GUIDE and have to realign everything.
I finally took the top nozzel into the shop and filed the top end down and rounded off the edges making the overall length shorter.  This worked and it went back in with no problem.
As I already said,  I don't ever remember having this problem in the past.  The only thing that has changed is a bad roller guide was replaced.  Has anyone else had this issue?
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Lubmizer Nozzel Issue
« Reply #1 on: April 13, 2018, 10:09:29 AM »
Other than the fact that they like to seize in the hole, I've had no problems changing nozzles.
Offline steve marek
« Reply #2 on: April 13, 2018, 10:24:58 AM »
I had same thing happen I filed a bevel on top to get back in
WM LT40HD Logrite ach 718 woodmaster timber framing tools 3000 ford tactor 359 husky chainsaw woodmizer e50 single blade edger
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: April 13, 2018, 12:42:15 PM »
Same here, top one I filed down.  Maybe earlier ones which were replaced were shorter, I don't know.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline scully
  • Orange Mills Matter
« Reply #4 on: April 13, 2018, 05:14:47 PM »
I took mine off and made the hole bigger . I had to remove the roller , but not a big deal .
I bleed orange  .
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
« Reply #5 on: April 14, 2018, 09:01:25 AM »
Mine kept plugging so I just removed them and let the lube/coolant gush out.
I find that more seems gets on the blade this way as the spray nozzles way over sprayed the blade
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: April 14, 2018, 09:18:43 AM »
I drilled the top nozzle out to 1/16" (I think).  Anyway it stopped the clogging and still sprays.  The lower one seldom if ever clogs.
2006 LT40 SHD Lubmizer clear tubing type? size?
Started by Blazer406 on Sawmills and Milling
Last post October 03, 2011, 01:53:29 PM
by Magicman
GFI issue
Started by Raider Bill on General Board
Last post May 24, 2017, 02:51:53 PM
by Raider Bill
262xp issue
Started by northern on Chainsaws
Last post June 11, 2010, 06:50:05 AM
by northern
computer issue
Started by drobertson on General Board
Last post March 22, 2015, 06:12:07 PM
by drobertson
