Author Topic: straightening a tree out  (Read 664 times)
Offline edward johnson
« on: April 14, 2018, 12:29:36 AM »
I have a 14 foot or so walnut tree that is shaded by a lilac bush.  The tree is leaning out searching for light.  I trimmed the bush and tied splints to the tree.  This helped a little.  Any suggestions to achieve better results?
Offline mike_belben
  • Pulp Friction
Re: straightening a tree out
« Reply #1 on: April 14, 2018, 09:42:55 AM »
Thread two eye bolts into your splints or make a collar up a ways that can anchor snooth fence wire without harming the tree.  Run a strand up from a ground stake, through the loop and back to the stake.  I suggest two of these at 45* to the lean to create a tensioning bipod.
Now anchor the ends of the wire to their respective ground stakes, pop a stick between the lines and rotate it, causing these guy wires to twist together and shorten.  You have a constantly variable screw type winch.  This is how fence post corners are cross braced in the south.  Leftover scraps of barbwire and a twisting stick between em.
Revelation 3:20
« Reply #2 on: April 14, 2018, 08:13:29 PM »
thanks i think ill try it with three stakes.  Tri pod.
Offline mike_belben
  • Pulp Friction
« Reply #3 on: April 14, 2018, 10:29:19 PM »
Sure, you can use as many as it takes and they can be at different heights as needed to straighten out a bow too.  The turnbuckle sticks will let you dial it all in just right.
Let us know how it turns out.
Revelation 3:20
Straightening a bar.
Started by luvmexfood on Chainsaws
Last post October 03, 2014, 06:28:18 PM
by JohnG28
Straightening a band
Started by cantcutter on Sawmills and Milling
Last post January 04, 2008, 08:45:21 PM
by Minnesota_boy
Straightening steel shaft
Started by sprucebunny on General Board
Last post November 14, 2006, 06:08:41 PM
by SwampDonkey
sad
Bushfires Australia story featuring video - Tree Cutting and Tree Removal
Started by acetree on General Board
Last post July 24, 2009, 10:15:06 AM
by acetree
