Baltic Abrasives Technologies
Author Topic: I Put Gas in My Diesel Tank  (Read 4410 times)
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« on: April 15, 2018, 02:41:53 PM »
4 gallons of gas was put into my diesel tank to top it off when I left Georgia.
I was sick. I made it home on my other tank.
Now keep in mind I NEVER switched over to the tank that had the gas in it.
So when I got home I got in touch with you guys for help, I looked on You Tube, I called every machanic I personally know, I looked in my 97 F-250 7.3 Power stroke Manual and finally this is what I did.
First let me say we are talking about M.R. M.Y. TRUCK.  :D :D :D :D :D
My stupidity by not paying attention made me sick!  smiley_sick
Second...if you don't have one of these pumps they come in handy. I've had this pump for 15 years and have different length hoses to suck oil, gas, diesel, water or whatever.
I ran the hose in the tank and started.
As it filled I then poured it in the 5 gallon bucket then transferred it to my 55 gallon barrel.
It took about 30 minutes but I pulled 18 gallons out of that tank.
After that...and since I was at the mill.....I put in 3 gallons of clean off road and sucked it out.
When I got that 3 gallons sucked out 2 more gallons of fresh off road and sucked it out.
Then off to the service station.
I was able to fill the tank with 19.129 gallons of clean fuel.
Filled the other tank and I was ready.
I drove it down a country road at about 75mph and hit passing gear several times.  M.Y. Truck is running like a new one again.
About the ATF in the tank....3 of my shade tree buddies said to do that also.
But I did read on line what as happened to some engines before.
So I chose just to drain, add more fuel, drain again then add more fuel and drain that then fill up.
So far no problems in 8 miles and I feel like if something was gonna happen like spitting, coughing, sputtering or just plane shutting down it would have happened by now.
Thanks for listening.  :)
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Re: I Put Gas in My Diesel Tank
« Reply #1 on: April 15, 2018, 03:07:30 PM »
I think U done good
dilution must have been the solution.
Years ago a friend of mine put diesel in his gas tank.
Took him 2 weeks to find out why it wouldn't start. must have been the solution.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: April 15, 2018, 03:16:01 PM »
David,
   My only concern was when you said you put the off road diesel in then sucked it out. I'd be afraid the cops would check it some time in the future and find even the trace amount of the markers they put in it the off road diesel. I understand they are pretty tough on truckers when they find that. I am sure others with more experience can address that too.
   Neat pump BTW.
Offline thecfarm
« Reply #3 on: April 15, 2018, 03:19:07 PM »
Glad you got it. 8)  I can imagaine what you was thinking. $$$$
Offline starmac
« Reply #4 on: April 15, 2018, 04:25:03 PM »
I have added a gallon or two of gas many times to my old 6.9 and 7.3 diesels in cold weather. I have added 5 gallons or so to my big trucks a few times too, but those tanks hold 100 to 150 gallons too.
Offline Sixacresand
  • John and Nancy
« Reply #5 on: April 15, 2018, 04:33:05 PM »
Glad you got it straightened out.
Offline goose63
« Reply #6 on: April 15, 2018, 04:34:29 PM »
David,
   Neat pump BTW.
David that fine can start at 10 grand drive that tank empty 2 or 3 times change filter do that 2or 3 times and you should be ok with no more red fuel in the tank
goose
thank you to all the vets
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #7 on: April 15, 2018, 04:47:15 PM »
We had the same thing happen 30 odd years ago. Barb went to fill up the truck, told the attendant to fill both tanks with diesel, and left him to it for a few minutes. When she came back she saw the guy filling it with the "premium" hose on the other side of the pump. He told her "they didn't make a diesel version of this truck." ::) ::)
Fortunately he had only half filled one tank. She brought it home on the other tank and I drained it and "cleaned" it exactly the way David did (except I only added clean fuel once). The truck ran just fine for another 20 years.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline brianJ
  • Only get excersize if I choose the right hobby
« Reply #8 on: April 15, 2018, 04:50:00 PM »
On purpose as a gelling prevention?    Did you run them that way?
« Reply #9 on: April 15, 2018, 04:56:18 PM »
Well I have to admit I almost made a boo boo.
A guy at the service station I stopped at the 2nd time said leave the gas in it and just add ATF.
I'm just glad I made it home on the front tank, thought about it all night while I slept, talked to a lot of people and made a good decision.
It was like a bad dream.  :D :D :D :D.......in fact it still is.  :o :o :o
Offline slider
  • sawyer,trucker,tree service
« Reply #10 on: April 15, 2018, 05:01:05 PM »
 Where did you find that pump ?
al glenn
« Reply #11 on: April 15, 2018, 05:11:38 PM »
It was at the service station. I just pulled right up to it and filled up. SEE.
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
I'm just playing with you Slider.... what's that you just called me?  :D :D :D :D :D :D :D
I saw that pump at my lawn mower shop. They use it for taking oil and gas out of lawn mowers.
The boat place uses them also.
I asked the lawn mower guy to order me one. He did 15 years ago and it sure has come in handy.
I'll find out where he got it and post it. You need one. It will fit in your buddies beer can and he will never know where his beer went.  :D :D :D :D :D
Offline Red Clay Hound
  • Retired - Now Turning Logs into Lumber
    • Broad River Mobile Sawmilling, LLC
« Reply #12 on: April 15, 2018, 05:32:58 PM »
I have nightmares about doing that very thing!  Every time I fill up I remind myself Im driving the truck and not the car.  Makes me nervous when my son borrows my truck too.  Hes not in the habit of pumping diesel! arg-smiley
By the way, it was good to see you at Jakes!
2007 Wood-Mizer LT40 Super Hydraulic with 51 hp. Cat; 2007 Wood-Mizer EG200 Twin Blade Edger; Woodmaster 718 Molder/Planer; Stihl MS460 and MS362 Chainsaws; 2011 John Deere 5065 with JD 553 Loader
« Reply #13 on: April 15, 2018, 05:35:28 PM »
Been missing ya! Glad to see you too.  :)
Offline red
  • we will never forget
« Reply #14 on: April 15, 2018, 06:28:59 PM »
Daydreaming getting out of the truck. . Wishing you lived in New York and eating Danny's NY pizza you grabbed the wrong filler nozzle
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline Southside logger
« Reply #15 on: April 15, 2018, 06:38:19 PM »
So you have a gas tank sucker out thingy.... Hummm..   :D
Offline breederman
  • getting by the best way I know how
« Reply #16 on: April 15, 2018, 06:47:35 PM »
I filled the work truck with gas once and didnt realize it untill it started skipping I Was real close to a Ford dealer and  they pumped it out and told me to buy a lottery ticket! Truck still ran great when i turned it in over 100000 miles later
Together we got this !
« Reply #17 on: April 15, 2018, 06:48:29 PM »
:D :D :D
Offline customsawyer
    • The Custom Sawyer
« Reply #18 on: April 15, 2018, 06:57:53 PM »
Glad you got it straitened out. Don't beat yourself up to much, that's my job. lol
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
« Reply #19 on: April 15, 2018, 07:13:41 PM »
Good 1 Jake! 😂😂😂😂😂
Diesel in lube tank
Started by clintnelms on Sawmills and Milling
Last post December 25, 2016, 02:42:41 PM
by hacknchop
Diesel Tank for Property
Started by wfcjr on Forestry and Logging
Last post January 06, 2015, 06:16:40 AM
by luvmexfood
diesel tank leaking
Started by slider on General Board
Last post July 26, 2012, 02:01:26 PM
by beenthere
Diesel in lube tank
Started by Crossroads on Sawmills and Milling
Last post November 14, 2018, 10:20:59 AM
by armechanic
