Council Tool
Baltic Abrasives Technologies
Author Topic: LT 35 engine upgrade  (Read 1334 times)
Online Southside logger
« on: April 16, 2018, 08:36:50 AM »
Ok - So I think I am going to order a Riehl edger and they offer it without an engine at a discounted price.  Hoping to kill two birds with one stone and my though is to take the 25HP Kohler off my LT35 and use it on the edger to give her a good, solid power unit.  In its place on the LT 35 I was thinking of putting a Kohler 35HP 999cc carb engine.  https://www.kohler-engine-parts.opeengines.com/horizontal-twin-cylinder-ch-ch980-3538-hp-999cc-c-781_72_151_328_476/kohler-engine-ch9803013-35-hp-command-pro-999cc-woodmizer-p-12224
I figure the extra torque will make the 35 sing and increase production.  Looking for input on the sawp, the only potential issue I see is the up / down motor, which I could upgrade if need be.  I called Indy and they said they don't offer a kit for such a swap and that they had not tried such a set up so really could not offer any advice.
What say you?
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
Re: LT 35 engine upgrade
« Reply #1 on: April 16, 2018, 08:46:18 AM »
The Kohler 999 is a significant upgrade.  I 8had Woodmixer upgrade my LT40 to the Kohler 38 HP fuel injected version last summer.   The engine required a new baseplate, pulley and alternator.   I think it would be extremely difficult to do on the LT35 as it uses the LT15 head assembly.
You are welcome to come over and look at mine to decide if it is something you want to tackle.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Online pineywoods
« Reply #2 on: April 16, 2018, 09:20:45 AM »
weight will be a problem. This worked fine on my old lt40 when I did an engine swap
Faster UP for older woodmizers in Sawmills and Milling
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #3 on: April 16, 2018, 10:03:19 AM »
My concern would be the LT35's ability to carry the extra weight. Its cantilever system is quite a bit different and I'm assuming less rugged than the LT40.
1992 LT40HD
Offline ladylake
« Reply #4 on: April 16, 2018, 10:09:57 AM »
 According to Kohlers website the 35hp is only 12# more than the 26 hp    .  Steve
Timberking B20 12000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Dino setter Volvo MCT125c skid loader
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #5 on: April 16, 2018, 10:44:07 AM »
Do it!
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline Deere80
« Reply #6 on: April 16, 2018, 12:09:34 PM »
 Sounds like an awesome idea to me, go for it.
Wood-Mizer LT35HD
« Reply #7 on: April 16, 2018, 08:34:53 PM »
@DR_Buck I will take you up on that.  What was it about the alternator that was different?
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #8 on: April 16, 2018, 10:26:59 PM »
Hello,
  I would not recommend adding the extra weight to the LT35 saw head. My guess is that you will bend the metal that the up down bearings are suppprted by. I have replaced two of these already one was damaged by a truck mirror catching as it drove by and the other was hit by a log.
Hope this helps.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
« Reply #9 on: April 16, 2018, 10:35:15 PM »
Did the guy driving the log at least stop to check on the mill?   :D
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #10 on: April 17, 2018, 08:25:01 AM »
The alternator is mounted different and is huge compared to the 25 HP one.
Hidden Acres Farm
Online pineywoods
« Reply #11 on: April 17, 2018, 09:37:25 AM »
The real gotcha will probably be the main drive belt. A single belt likely won't handle 35 hp. Not much way to add a second belt..
« Reply #12 on: April 17, 2018, 05:21:24 PM »
It has a double drive belt on there now.
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #13 on: April 17, 2018, 08:39:56 PM »
I think the 38HP uses a triple wide belt.   I'll need to look at it tomorrow to confirm it.
Hidden Acres Farm
engine upgrade
Started by Engineer on Sawmills and Milling
Last post June 14, 2007, 01:11:53 PM
by tomboysawyer
6-13/6-14 Lucas engine upgrade?
Started by DDobbs on Sawmills and Milling
Last post May 10, 2016, 05:25:54 PM
by DDobbs
wood mizer lt40 engine upgrade
Started by timbrr63 on Sawmills and Milling
Last post December 03, 2013, 12:48:55 PM
by timbrr63
Looking for input on future engine upgrade/replacement
Started by Two Trax on Sawmills and Milling
Last post November 05, 2018, 12:38:32 PM
by barbender
