Eastern Red Cedar seeds question
Started by ant888nsmb2, July 04, 2018, 07:20:02 PM
ant888nsmb2
There's 2 seven foot eastern red cedars in my relative's backyard, and was wondering if there's a way I could possibly propagate the tree (either by seed, or by cuttings). Are the seeds in those little blueish berries that grow on the tree?
Southside
You can grow them from cuttings but it isn't the easiest one to do. Those are the seeds and usually they are spread through a birds digestive system, so you need to prep them in a similar fashion.  If I remember correctly soaking them in citric acid after a hot/cold exposure is necessary.  Are there any little seedlings around the trees you could transplant to make it easier?
White Oak Meadows
ant888nsmb2
Sadly there's no seedlings growing near the main trees. I have access to seeds though. I tried looking online about how to sow the seeds, but didn't find any info.
clearcut
The Woody Plant Seed manual describes  the specific treatments. Author(s): Franklin T. Bonner; Robert P. Karrfalt
Date: 2008
Source: Agric. Handbook No. 727. Washington, DC. U.S. Department of Agriculture, Forest Service. 1223 p.
Eastern red cedar is in the Cupressaceae and is described under Junperus virginiana.
https://www.fs.fed.us/rm/pubs_series/wo/wo_ah727.pdf
Carbon sequestered upon request.
ant888nsmb2
Thanks for that amazing pdf. That'll help me a lot!
LeeB
If you want to come to Arkansas, I'll be happy to let you dig up thousands of them.  :D
ant888nsmb2
LOL how many are growing?
But seriously now, the according to a guide I found on the Internet, the seeds are located inside those berries.
wesdor
Thank you Clearcut,  that is a great resource!
btulloh
They are for sure .They're easy to propagate .
HM126
TKehl
Quote from: LeeB on July 05, 2018, 09:33:55 AM
MO is closer.  PICK ME!!!
Seriously, there are guys here that have built businesses on cutting, stacking, and burning ERC that has overgrown pastures.  Not super hard to control, but if you wait to many years without brushhogging they'll take over fields.
In the long run, you make your own luck – good, bad, or indifferent. Loretta Lynn
ant888nsmb2
I guess I got kinda lucky. I found two very small seedlings on my own lawn! I will be transplanting when the rain stops.
