'new' old saws....
Started by mrcaptainbob, October 20, 2018, 05:44:52 PM
mrcaptainbob
Just picked up three saws:
A Poulan Pro PP4218 (mix 40:1)
A Poulan 306A (mix 32:1)
A Wards TMY 24084A (mix ?:1)
I believe they run. Reluctant to start without correct fuel mix. I believe I found the correct mix for the two Poulans, but cannot find info for the Ward's. Any ideas?
lxskllr
I don't think it matters much. I'd pick a mix ratio, and use it for all of them. Something between 32 and 40 to 1 should work. 50:1 should work too if you're using good oil. My PoulanPro I always used 32:1 in. Made the math easy mixing in my 1L bottle.
sawguy21
X2 Oil technology has much improved since those saws were built.
mrcaptainbob
I presume the Stihl oil is in that category. Already mixing a container at 40:1 for an Olympyk, so this works quite nicely. Thanks for the help.....
