how to repair holes in water tank
Started by Polly, November 09, 2009, 08:26:09 PM
Polly
 :( 8) i have a 1500 gal water tank i use to haul water the underside of the tank is rusted with little pin holes in anyone got any sugestions in how to repair ::)
Stan snider
Ironwood
Roll it over and put pin holes at top ;D
Ironwood
zopi
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Jasperfield
Be it steel or polyethylene, pinholes indicate it's pretty well shot. You may be better off planning to replace it.
shinnlinger
There are products like Kreme which can coat the inards, but once you go through all the steps and expense you probably are better off just replacing it.
Shinnlinger
LAZERDAN
Nonsense::    Empty tank.   go to big box store,   Buy polymar floor leveler,  pour it in and wha-la   Worked for us. Or ask Sherwin williams, You've got the world wide web @ your fijnger tips     Lazerdan  sigh in off
WildDog
For standing gal tanks that rust out in the bottom we just throw dry neat cement (not mixed with sand or gravel) not sure how it would work for a transporting tank, when a gal tank has pin holes in the side to prolong it I stand back and throw dry cement at it till it takes up once again it wouldn't probably wotk on a mobil tank.
If you start feeling "Blue" ...breath    JD 5510 86hp 4WD loader Lucas 827, Pair of Husky's 372xp, 261 & Stihl 029
fishpharmer
Welding a patch will probably hold up best on a steel mobile tank. Use mig or tig.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
pineywoods
If it has pin holes in the bottom, you can bet it rusted through from the inside. Hit one of them holes with a welder and POOF you will have a much bigger hole.
