Author Topic: the best grease  (Read 3388 times)
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
the best grease
« on: January 25, 2018, 06:14:59 PM »
Anybody use green grease?
the description makes it looks like it can do everything.
I am looking for the best for my mill , wheel bearings and my atv which spends quite a lot of time in the  water and in mud
I have used the cheap stuff and just had to do the bushings on my atv and wonder if it is detrimental to the mill and my other equipment, tractor, rtv etc
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: the best grease
« Reply #1 on: January 25, 2018, 07:42:43 PM »
Everyone's going to like something different... Like ford and Chevy...
I like red moly my self.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: the best grease
« Reply #2 on: January 25, 2018, 07:47:01 PM »
Man we just had a thread turn into this lol I cant remember where tho.  I use Schaeffer’s 238 moly supreme on my pins that stuff can not be beat for that.  Everything else I been using either the mobile delvac or the lucas red n tacky.
Boy, back in my day..
Offline Chuck White
  • Sawing Mobile since 2005
Re: the best grease
« Reply #3 on: January 25, 2018, 08:31:08 PM »
I remember part of that post!
In it I believe MagicMan recommended NLGI #2 grease!
I think it was mentioned that it would withstand high pressure, high heat, and high speed!
~Chuck~
I LOVE MY SAWMILL
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
Re: the best grease
« Reply #4 on: January 25, 2018, 08:31:17 PM »
http://forestryforum.com/board/index.php/topic,97721.msg1509037.html#msg1509037
This one?,  Nope not that one ::)
http://forestryforum.com/board/index.php/topic,99260.msg1535287.html#msg1535287
This one
D
Offline farmfromkansas
Re: the best grease
« Reply #5 on: January 25, 2018, 10:42:58 PM »
I have been using a lithium base grease,  find it expensive but also find that i have few breakdowns using it.  Have been using it several years on my farm equipment.  It is recommended for my sickle mower.
Offline longtime lurker
Re: the best grease
« Reply #6 on: January 26, 2018, 03:11:39 AM »
Grease is grease: which is to say that cheap grease often beats good grease seldom. Particularly when the application is either as a cushion (hitch pins, suspension bushings etc) or where it has to also function as a seal to keep moisture/ dirt out.(automotive ball joints etc).
I use whatever mid price moly I can get on special in those types of application.
Bearings I use a proper bearing grease like mobil temp#2.
If its something that needs good grease because I won't be back in their until it fails I use Mobilith SHC460... extreme temp and pressure resistance and sticks like nothing else I've ever found.  But too much$ for things like ball joints.
At the extreme ends there are graphite greases and process greases. But grease is like oil in that its not just grease - there is an inverse relationship between the speed(viscosity) of grease and the cushion or "stick" of grease. So: a grease suitable for electrical motors is not the grease suitable for a shaft bearing on a 25000 HP fuel oil engine.
But for general applications like your quad bike... grease is grease.
Offline Kbeitz
    • My Hobbies
Re: the best grease
« Reply #7 on: January 26, 2018, 06:24:54 AM »
Grease is grease but the soap that hold it together is different...
Offline PA_Walnut
Re: the best grease
« Reply #8 on: January 26, 2018, 06:28:39 AM »
I've come to realize that greasing more often is better than greasing "with better".
Got a 20V Dewalt grease gun, now that Red-n_tacky flies as often as possible. I think I'm even exceeding the recommended intervals!  8)
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline kelLOGg
Re: the best grease
« Reply #9 on: January 26, 2018, 06:33:08 AM »
I use Red n tacky in the summer and some black grease in the winter. Does anyone else change grease with the seasons?Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Oliver05262
Re: the best grease
« Reply #10 on: January 26, 2018, 08:39:33 AM »
Well, the Red & Tacky doesn't pump well when it's cold. so unless you keep the gun on the floorboard under the heater, you need to use something else. Most synthetic greases fill this need, but at a higher cost. It is a trade off.
"You can't do wrong by doing good"
It's OK to cry.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: the best grease
« Reply #11 on: January 26, 2018, 09:46:39 AM »
Just remember NLGI 2
Online 69bronco
Re: the best grease
« Reply #12 on: January 26, 2018, 09:50:27 AM »
Red tacky for me.
Online Percy
  • Resident trouble maker
Re: the best grease
« Reply #13 on: January 26, 2018, 10:41:05 AM »
When I was a kid just outta highschool driving log truck, I asked an oldtimer what was the best grease??, he said "The stuff in the kingpins and tie rod ends and slack adjusters is much better than the stuff  in the grease gun" ;D ;D
Offline Resonator
  • Board Footage and Cord Woodage
Re: the best grease
« Reply #14 on: January 26, 2018, 01:33:49 PM »
Any grease is better than no grease at all. I've seen some excavators that come with a self lube system built in. Sending controlled amounts of grease from a tank through pressurized lines to the bushings. I had an old JD 310A backhoe, (well worn before I got it), that you could rock the digger bucket side to side because of loose wrist pin bushings.
Offline dustintheblood
  • Home in the woods
Re: the best grease
« Reply #15 on: January 26, 2018, 01:36:58 PM »
Elbow
Case 1494, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln, plus other toys - cause well - gotta have something to play around on
  • Home in the woods
Re: the best grease
« Reply #16 on: January 26, 2018, 01:37:17 PM »
Bacon
Offline moodnacreek
  • Sawin by the notches
Re: the best grease
« Reply #17 on: January 26, 2018, 06:59:18 PM »
When I built the sawmill that I operate, bearing heat was a big problem because the center of the saw would warm about 5  degrees and throw it off. First off I was using too much grease and too heavy a grease. Went thru 3 lubrication salesmen, all a waste of time. Now too much grease heats a bearing; one day I pried the seals off a new Timkin/fafner sealed, non relub ball bearing and found it FULL of blue grease. This special grease they sell and it will reduce the bearing temperature. this can be the difference between sawing and not sawing. The gravity rolls that go to my lumber separator must have thin grease in winter. After rebuilding my Prentiss loader I have only used L.E. synthetic grease. On simple ,slow moving or loose joints I will use common # 2 grease.
Offline richhiway
  • Rich
Re: the best grease
« Reply #18 on: January 26, 2018, 07:23:16 PM »
for outdoor equipment a good water resistant grease works well. I use Amsoil Synthetic water resistance grease in everything I own including wheel bearings. It cost a little more but you will use less of a quality product. Synthetic oils and greases work better in cold and hot conditions.
Grease does not lubricate it is the oil that is held in suspension that does. If you over grease you do not give the oil a chance to work.
https://www.amsoil.com/shop/by-product/grease/synthetic-water-resistant-grease/
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Re: the best grease
« Reply #19 on: April 11, 2018, 06:58:35 PM »
I now have the dewalt 20 v gun and am trying lucas redn tacky and green grease.
We'll see what happens
the green grease is really sticky
Also found a torn boot.
LT40SHDD51
Kubota 900 RTV
question
Grease
Started by David_c on Forestry and Logging
Last post June 14, 2005, 10:42:01 PM
by WV_hillbilly
Grease Job
Started by Kevin on General Board
Last post May 18, 2004, 02:39:45 PM
by shopteacher
Bar Grease
Started by Kevin on Chainsaws
Last post March 16, 2004, 10:34:30 AM
by Frickman
Grease??
Started by Magicman on Forestry and Logging
Last post September 15, 2010, 07:50:54 PM
by Magicman
