Dog Board on (1986) LT30
Started by Chuck White, April 09, 2018, 07:34:28 AM
Chuck White
I went and helped my new Amish neighbor pick up his recently purchased LT30!
The seller made the comment "I don't really like it because the Dog Board must be 2"!
I didn't want to discourage the sale, so I didn't say anything until we were on the road with it!
I told the buyer that if it's true, just lay a 1" board on the deck, under the 2" then you can saw the dog board at 1"
Is this how the LT30 owners do it, or is the 2" dog board issue even true?
47sawdust
It was true on early WM don't know when the change was made to be able to saw to 1''.Many have done what you suggest,others have added 1'' steel stock to compensate.
Mick
On my 1986 lt30 mill it is 3" not two, and it is a pain. When sawing I saw a 3" cant out of the first log that will saw a a nice straight cant, then keep that aside for when I need to saw closer to the bed than 3"which is usually every log. It is the one thing I do not like about my old mill.
Chuck White
Thanks for the replies!
The second owner of this mill was Amish, and a few things were changed over!
The feed is now "push through", and the up/down system now has a hand-crank on it!
He still has all the parts that were taken off!
The mill has a 16hp Kohler, and that's the only thing the battery is used for!
Neighbor/owner says he's only going to use it on his & his brothers farms, so the tires have been removed and he's going to run it on the rims!
We borrowed the wheels off my mill to go get it!
Crossroads
When I had my 85 lt30 I added 2" to the bed, but was still only able to get down to about 1 3/4" because of the idle side guide roller/adjustable slide would still hit. It is possible to notch the 2" lift kit so things would pass, but without relocating the guide rollers I don't think you could get below about 1 1/2".
trapper
With my 1987 LT30 I can cut to 7/8
jb616
I added 2x2 tubing on my '85 but I think i only made them 16" long so that I could get down to that last inch because I have to clear the bottom of the roller guide wheel. I made a mark on the slide for the adjustable end of the guide wheel. Most logs are able to sit on that 16" but I have 6" extiensions that I can slide on as well. You also have to watch out for the log clamp. I profiled the head of the clamp a bit to make it easier to get by and also cut off a quarter inch of the tabs on the bar of the log clamp to get it to sit lower if I want. Still thinking about making more mods to the log clamp like moving the lever down a little bit to clear better.  Also, I believe that the newer models don't have the lower guide wheel. Maybe modifications can be made to that for more clearance. Always thinking, always changing.
CCCLLC
WOW! Never heard this before. My oldest mill is a1990 lt40. It has the flip clamp so I make it down to 7/8". 1990 was cutting edge then.
