pioneer leveling
Started by dustyhat, December 14, 2015, 08:39:04 PM
dustyhat
Just wondering today while working on my barn, what the old timers used for levels. dont guess they had bubble levels or did they . i imagine in the big city's there was something, but out on the frontier . just wondering.
Jim_Rogers
They would use a string and a plumb bob. But the string was attached to a triangle made out of wood normally with the base being flat to the bottom of the legs of the triangle.
Not like this:
Then if the string aligns with the center mark on the bottom of the triangle then the base is level.
Do you understand what I mean?
Jim Rogers
dustyhat
Absolutely, that is very interesting i like old tools just never thought about it till today . very big thanks, just shows your never to old to learn.
dustyhat
I looked it over again , simple but amazing.
Jim_Rogers
It is an ancient way of leveling without water/bubbles.
Jim Rogers
Roger Nair
Following on Jim's theme, triangular frames can be mounted on straight edged beams of any convenient length.  The registration marks can be checked by rotating the ends, if you align to the same mark you are level, if not level will be halfway between the two readings.  Precision without cost.  Similar devices with a quadrant can be used as inclinometer.
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
tyb525
Not quite as old pioneer days, but the water level was something I was shown a few years ago, usually takes 2 people, good for leveling distant points. Just a piece of clear tubing whatever length you need, filled with water. Put the level of the water at the point you want to level from, and at the other end the water will be at the same level once it stops moving.
Den-Den
Quote from: tyb525 on December 14, 2015, 09:19:22 PM
A water level with a reservoir at one end (5 gallon bucket in my case) is very accurate and only takes one person.
Brian_Weekley
Got to hand it to those wiley Egyptians with their water levels made with Tygon, clear, plastic tubing...   :)
I've used mine on several occasions--it's a great low tech tool.
e aho laula
pineywoods
The ingenious craftsmanship of our pioneers has always amazed me. To build a building  using nothing more than an axe, crosscut saw and string is absolutely amazing. Those old pioneer log homes in this area were always level, plumb and square.
starmac
For those that haven't thought of it, a little food coloring in the water used in a water level, sure helps old eyes.
SLawyer Dave
In Peru, over 2,000 years ago,  the Nazca built very elaborate aqueducts both above and below ground to carry water out into the dry coastal areas they farmed and into their towns.  One of the things noted by archaeologists and engineers, was that their aqueducts invariably were built at exactly the same grade.   This was a great puzzle, because no one could figure out how they could have built something so exact with the primitive tools they had available.  The secret turned out to be their elaborate pottery technology.  They designed and built "water bowls", that contained a hollow view piece through the bowl.  So you would fill the bowel, make sure the water was exactly even, (therefore level), then you could look through the tube, and it would be set at exactly the angle they were to build to.  That way, no matter how far away, you could look through the tube, and adjust the plot lines.  Very simple in concept, but amazingly accurate.
jueston
Quote from: pineywoods on December 15, 2015, 11:20:21 AM
i would just throw out a small caveat to this statement....
Those old pioneer log homes in this area *that survived until today* were always level, plumb and square.
my guess would be the low quality log homes were abandoned or rotter or tipped over, so you might be judging an entire group of people based on the best 1% of their craftsmanship...
