Mystery Jack
Started by TheDirt, May 16, 2012, 04:28:06 PM
TheDirt
I'm looking at buying an old Timberjack cable skidder. I've been using it on a job when it's dry enough for about a month and so far it's run pretty well for me. I'd only run JD and Cat skidders before so it took some getting used to. I can't seem to get a confident answer from anyone as to what year and model it is exactly. I know it's newer than '68 due to the control setup but the model is a little harder to identify.
For starters it has the 18.4x26 tires and the bigger rockwell hubs and planetaries. however wheel base measures narrower than the 230, can't remember exactly what.
it also has a perkins 4cyl motor, which I am not sure is original or not as it looks like the machine might have been plumbed for a detroit originally. It's got a hercules winch and can only be entered from the operators left hand side.
The serial number is partially rubbed off.
It seems too big to be a 208 and too narrow to be a 230, a 225 is my present theory but I've never heard of one with a perkins, but it might not be original. Anyone who knows these machines have any idea?
I can get some pics next time I'm up to the landing.
lumberjack48
Being it has the Rockwells it was originally plumbed with a Detroit, TJ came with a Perkins, but that machine had the lite hubs, [who knows?]
Tramp Bushler
You might alter the title . I thot I was going to be looking at Duff Norton falling jacks
If your not wearing your hard hat when you need it. Well.
Tramp Bushler
As it is port side entry it would have to be a 2 series or a 404 .
lonewolf
My guess would be that its a 209. I have a manual that gives me the width and lenght of the 200 series jacks if u measure it I may be able to tell you.
"EARTH FIRST"  WE'LL LOG THE OTHER PLANETS LATER
TheDirt
Thanks a lot for the advice guys,
Yeah Lonewolf I will take some measurements tomorrow, should be interesting, never heard of a 209...
TheDirt
So,
I got 80" rim to rim (width)
and 112" axle to axle (length)
lonewolf
My manual shows 79 in width inside width on rims and 110 axle to axle on 209 tj hope that helps.
lumberjack48
1968, 209D, factory Perkins 4-236, with heavy Rockwell rears
bushmechanic
217D came with the larger Rockwells and a Perkins diesel
Tramp Bushler
Do you have any pics of it . ?
TheDirt
Thanks for the replies, bushmechanic, lumberjack48 and lonewolf. Tramp Bushler, I will get some pics up this coming week, I have been on another job and away from my computer for a bit.
Really appreciate the help!
-D
TheDirt
Here are some pictures I took today.
Corley5
bushmechanic
I'll stick with 217D.
lumberjack48
Its hard to tell, this is a pic of a 209D
rvolek
Nice machine!!!! Love the TJ's
74 Timberjack 230D
JD 450 Dozer
Husky 570, 372
treefarmer87
it is a good lookin skidder. im not sure of the model though. :-\
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
grassfed
I might be wrong but the tires look more like 18.4x34s than 18x26s to me...
Mike
lumberjack48
Quote from: grassfed on June 08, 2012, 06:57:37 AM
My thoughts to, that Perkins is working for its keep, all 85 hp.
I ran a C4 TFarmer with the Perkins, it was a good steady Edie machine, cheap to run.
TheDirt
Good eye grassfed; they are 18.4-34's indeed, I had the 18.1x26's on a 540b I was using, I meant to correct that when I posted the photos.
She works hard to turn those tires. I am working on the side of a mountain so I have a long slow crawl up into the woods and a pretty wild ride on the way down, pretty much can't count on stopping if my hitch starts to push me on the ledgy spots.
I have been fairly satisfied with the machine. One thing I really don't like is the winch, I am used to the Gearmatics and this Hercules isn't even half of a Gearmatic 9.  Today the sleeve/ collar thing that the driveshaft goes into on the winch worked it's way up the shaft (out of the winch) and all of the winch oil dumped out. I found this out as I was trying to pull in a hitch of 5 Hemlocks with no success, I kept getting out and un hooking one after another, unable to figure out what was holding them. Finally I got the idea to look at the winch and the answer was pretty obvious, it was actually smoking...hopefully the damage isn't too bad...It's been a long week and it was starting to rain so I just walked away from it for today.
lumberjack48
We should all put a bounty out on Murphy, Enough is enough  8)
TheDirt
Well,
The winch trouble has turned into more trouble than I'd originally thought.
It pretty much jammed up and I had to remove it and take it to the shop to start tearing it down. Fortunately I was hooked up with a guy who knows his old winches and has wrenched on a lot of old skidders and crawlers.
We ripped it apart this afternoon and found the bearings on either side of the worm gear where the driveshaft attaches were finished and allowing the worm gear to jam up against the main brass drive gear and stop the whole winch. The shaft that the bearings ride on was pretty messed-up with grooves nearly a quarter inch deep. Fortunately this mechanic I mentioned happens to have a lathe and the know-how to build this shaft back up and smooth it out. In the process of the tear down I found that all of the bearings had been etched with the year "1969" so that at least might answer some of the original mystery.
My new problem however, is:
Though we could get most of the numbers off of the bearings (mostly Timkens, and one was a PITCHLIGN.)
There is a seal on the driveshaft side of the worm gear that we could not read the number off of. It looked like 21??-USA (the question marks were the scratched out numbers.)
If anyone has a manual that covers the Hercules Winches of that era I would be very interested in any help on what that number could be!
Thanks guys!
lonewolf
Tj part number 8206236
TheDirt
Thank you lonewolf!!!!!!
