Adirondack Chair Project
Started by kyjondeere, August 10, 2018, 10:23:02 AM
kyjondeere
Just completed this Adirondack Chair project using 4/4 black cherry off my farm and milled on my Lumbermate 2000.  I thought it turned out well for my woodworking skill level which is beginner or lower if there is such a thing.   :D
Here's a couple of photos.
Norwood Lumbermate 2000, John Deere 5083e, John Deere 5075e, Kubota L3240, Stihl MS 461, Stihl MS261CM, Load Trail 16' Dump Trailer
Ljohnsaw
Very nice!  Are you going to finish with a clear finish?  Will it live on a covered porch or will it be yard furniture?  I'd hate to see such nice wood baking out in the sun!
John Sawicky
kyjondeere
It will be on a covered porch.  I plan on finishing with clear Australian Timber Oil.
I would enjoy sitting in that talking to you. :)
Downstream
Very nice job.  Always extra special when you took it from tree to furniture.  Im pondering my next project.
EZ Boardwalk Jr,  Split Second Kinetic logsplitter, Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook, Dixie 32 Tongs
samandothers
Very nice and looks relaxing!  Did you build with green wood or did it dry for a bit?
LeeB
I like that design and have built quite a few of them just like it out of Cyprus, Cedar, and White Oak. Norm came up with a good chair.
WV Sawmiller
  Need to re-design the chair so the cat does not like it so much or you will never get to use it. :D
   Well done.
IMERC
Quote from: kyjondeere on August 10, 2018, 10:23:02 AMmy woodworking skill level which is beginner or lower
sure...
what ever you say...
uh huh..
your chair is very nicely done...
Who ever invented work didn't know how to fish.... Here fishy fishy....
kyjondeere
Quote from: samandothers on August 10, 2018, 10:21:36 PM
The lumber was barn dried for about a year.
kyjondeere
Quote from: LeeB on August 10, 2018, 11:11:16 PM
I plan on building some more out of tulip poplar, cedar, white oak, and maybe walnut.
LeeB
They are quite comfortable and very durable if built from a rot resistant wood. The first ones I built last 18 years out in the weather with no protective coating. The ones I built from white oak, only a few years. The cedar ones are still in use after about 4 years.
Dana Stanley
Looks really nice, but I think it could use another cross support higher in the back of the seat back, or the boards may tend to move out of alignment as they dry and stabilize!
Making Sawdust, boards and signs.
Woodland Mills HM-126
Kabota B-7800 with backhoe and loader
Ford Ranger, Husqvarna 455 20", Mac 610 24", other chainsaws 14", 23 ton log splitter
Matthew 3:10
LeeB
I've built the same design from green white oak, ERC, and cypress. Never had a problem with them. The cypress ones lasted for 18 years out in the weather, the cedar have over 4 years on them. The oak didn't fair as well but still usable after 4 years.
Ukrop
These Adirondack chairs are awesome! I wanted to craft my own ones too but couldn't find any good plan on the Internet.
Anyway, nowadays many manufacturers produce good Adirondack chairs not only from wood but even from plastic lumber. I must consider that our Highwood AD-CHL1-NBE chairs "stay alive" for 3 years already. But, of course, wooden chairs would be better. Nice work!
Not all those who wander are lost.
kantuckid
Quote from: Ukrop on April 26, 2020, 08:46:14 AM
There are several easily found patterns for those chairs sold. Look some more.
They don't work for us unless a wood that takes weather though.
I don't have a pattern for them but an outdoor type of chair I've seen all over the southern part of Yucatan, Mexico is the Mayan folding chair.
If you use google images you see them come up. the design is best if a piece of SS heavy wire makes the hinge point seen in the back seat folding area. They use a non-rot tropical jungle wood similar to teak. I'd use osage or white oak here.
They are even more comfy that the Appalachian chairs which require a pad for my butt to be comfy very long. Take a look/see.
RPF2509
I've seen some designs that have a reinforcing upright on the backside from the legs to the back cross piece.  To me the design you used looks cleaner.  Is your chair solid or could it use the extra brace?
Unclefish
Looking good . I want to build a some to. Watched some YouTube videos building some. Not sure if I have the patience to make them. Maybe next winter project
