Sealing or finishing cedar
Started by Kwill, December 24, 2018, 09:22:01 PM
Kwill
I am thinking about milling some cedar out like car siding to use in my house on the walls. I would like for it to have that shiny look like the boards you see people. Putting on the walls in cabins and stuff. I've never done any sealing or finishing of any kind so I kinda lost when it comes to it.  anyone been down this road and have any advice on what to use.
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
I have used satin polyurethane with good results.  I am not a fan of high gloss finishes.
Kwill
I like the look of the pine siding people use and wanted to do the same finish to cedar since I have an abundance of it. Most of it looks like a shiny finish.
opticsguy
Behr makes some excellent clear finishes for exterior exposures, limited to about 6? years for an exposed wooden deck and one whole heck of a lot longer used on siding.
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Bruno of NH
My house has all wood walls and ceilings except the ceiling in the great room and loft it has drywall.
I used cabots spar varnish in satin.
I like what spar does to the knots.
I have a wall of Windows that lets in a lot of sun.
The spar holds up well.
firefighter ontheside
Minwax polycrylic.  Choose the level of shine you want.  Test it on a piece before you put it on your wall.  It is water based, dries fast and has minimal odor.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Southside
Tongue oil works well with cedar too.
White Oak Meadows
rjwoelk
Minwax poly wipeon. 3 coats was good. Wipe it on let sit for a few min tgen wipe off excess. Wait 3 hrs light sanding repeat.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
