Moisture Content
Started by Randy, January 19, 2006, 03:22:29 PM
Randy
At what MC would it be safe to un-sticker air dried pine 1X and 2X and stack it flat onto each other---under a shed to stay till I get ready to use it in a year or two?? Thanks Randy
Den Socling
In SC in the summer, I would guess that the EMC outside would be high enough to add a little mold if you're dead packed.
Randy
Let me add this---------this lumber was cut close to a year ago and has been air stacked with a tin top. I wanted to restack under a shed and put all the boards into piles according to width and thickness, so when I needed certain size boards it would not be a problem to get to. I was hoping that I would not have to re-sticker it when I did this. So when is it safe to dead stack?? Thanks Randy
After a year drying it should be below 15% MC so it would be safe to flat stack as long as it didn't get wet again.
Mould / stain fungus shouldn't grow if the moisture is below 20%.
Just make sure it stays dry.
Den Socling
True in that you should not have a problem if all the wood is 20% or less. But way up here in Pennsylvania, the emc was 15% or more this hot, humid summer past. Know anybody with a moisture meter? Or for all you want to know - more or less than 20% a really cheap meter will do. If you get a meter, check a lot, not just one or two.
Randy
Quote from: Den Socling on January 19, 2006, 07:44:44 PM
Thanks, I have a moisture meter, but didn't have the knowledge to know what MC was safe to flat stack. I will check alot of boards as I do this. Thanks again!! Randy
