metal cutting blades
Started by xlogger, October 03, 2012, 08:57:33 PM
xlogger
Has anyone here use the blades that suppose to cut threw small metal in logs? I had a chance to get some pine logs today off a log yard that their metal detector pickup some "small" metal in the log. I heard that they cost much more and don't last any longer. I'll probably stay away from the logs but was interested in seeing if anyone uses them. Ricky
Metal cutting blades don't seem to cut wood well.
For a test, use a hack saw with metal blade and see how it goes. Get some powdery sawdust and goes pretty slow.
Unless you have a metal sawtooth design different than what I'm thinking.
Kcwoodbutcher
Bimetal or Cobalt blades will last a little longer but at three times the price of standard carbon blades it's a wash. I'm mostly an urban sawyer, you just learn to live with the nails. The glass insulator I hit yesterday is a different story.
My job is to do everything nobody else felt like doing today
If it was simple it would not be a problem.  Sometimes you can "jump butt" a log and get rid of the lower 3'-4' and saw the remaining short log, but if it is an antenna guy wire hanger, etc. then... :-\
Compensation
My WM blade cut a .45acp bullet in half and still was smooth. But one piece of copper covered lead isnt as bad as a piece of farm fence. At least i know what piece of wood my new coffee table is going to use :)
D4D caterpillar, lt10 Woodmizer, 8x12 solar kiln, enough Stihl's to make my garages smell like their factory :) Ohh and built Ford tough baby!
Common nails 16d and under usally won't lunch out a band especially if cut at a right angle.Drywall screws and the mentioned insulators can and will damage a band.If it wasen't for yard trees most of us small sawyers wouldn't have anything to cut.Find as much tramp as you can and take your chances.Sometimes I'll just cut a butt log for firewood if its stroon with hardware. Frank C.
Sawmill Man
Yes I tried them and found out I can ruin an expensive blade just as fast as the regular ones . They ran a little longer in dirty logs but hit one 16 penny nail and they were gone. They were bought just for logs that had metal. They were advertised as being designed to saw reclaimed beams that had metal, guess they were for people that didn't want to saw all the way through one.
"I could have sworn I went over that one with the metal detector".
Okrafarmer
A normal saw blade, at least the good ones, will get you through a 16 penny nail or two. I finished milling out an entire walnut log (it was a shorty) after hitting three nails, all with the same blade. It's those horseshoes, log chains, railroad spikes, T-posts, fence insulators, and antique tricycles that get you.
Now selling Logrite tools!
loggah
Up north here you can throw in old sap spiles in maple trees,the early ones are cast iron! Don
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
hackberry jake
Are the logs free? I never turn down free logs. Oh, throw pad lock in the list. They will stop a saw in its tracks. I would order a few cheaper bands and lay into em.
dblair
stay away from the first 6 feet from all trees that come from yards . that's just my experience with yard trees . I won't take another one from someones yard .
old Appomattox Iron Works circle mill.
Okrafarmer
Quote from: dblair on October 04, 2012, 07:21:35 PM
Oh, I will. That's where 90% of my logs come from.
xlogger
This logs where not free but real cheap. $10 per ton already debarked. The hand held metal detector could not pickup any metal but the one they use at the log mill did find something. The guy says that most of the time its small or even a bullet, never know for sure. They where 16 ft long and I needed some that long, the rest I had here where shorter.
