Has anyone Sawed brazilian walnut ipe
Started by just_sawing, October 13, 2015, 08:58:44 AM
just_sawing
Going to have to resaw some brazilian walnut ipe. I  use WM double hard 9 degree.
Wondering if I need to get stellite or something.
You can follow me at
www.http://haneyfamilysawmill.com
joejeep
I have never sawn Brazilian walnut, but I have sawn greenheart/purpleheart pilings. I used a 7degree blade that woodmizer recommended. Sawed very nicely, but dulled out ridiculously fast. Expect to go through a pile of blades. The pilings I have were never driven and very clean,,,wood is just hard as heck. I thought about stellite blades but the cost is up there, I figure just keep sharpening my bands as need be. Needless to say, I hate sawing greenheart. I did, however, take a few piles to another FF member with a wide band mill (Ludo), and he said his mill ate it up,, with no noticeable wear on band.
My wife says I do everything in excess
ellmoe
   I did a lot on planning on Ipe. I had to use carbide knives, steel knives wouldn't touch it.
Joey Grimes
Not ipe but I have sawn some azobe think it's close to same density. You are going to have to cut slow and change blades often .
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
just_sawing
Just got it done and only took four blades, Had enough soap in the water to blow bubbles. It was tough wood. Had about 30 1X6s 18 feet long.
