Stabalizing 2x4 for first cut
Started by Upper, October 14, 2015, 05:51:14 PM
Upper
I know the thoughts (Boy we really got a live one here).
  Tips a tricks are appreciated .............................................Upper
Stihl 661
Alaskan 36 CSM
36" guillotine splitter powered by a GMC V6
I like to build stuff
LT35HD Wood-Mizer
terrifictimbersllc
I don't understand the question. ???
Welcome to the Forestry Forum, Upper.
Adding your location and sawmill (?) will aid with answering questions.
Upper
Sorry I am talking about the first cut with an Alaskan Mill,using 2x4's as the guide.....Upper
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
Nomad
      Still too many questions Upper.  Are the 2x4s connected?  Are they supported so there's a flat solid surface to support the mill?  What's going wrong?  I guess I don't understand the question either.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Upper
Sorry for the confusion, I get that a lot.I have yet to use the mill and thought better of the 2x4's as opposed to a ladder.I would guess ths 2x's would not be bound.How is the best way to keep them from falling off the log.Hope someday we can rename the thread "Uppers first piece"....................Upper
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
BUGGUTZ
I dont have a pic but I will explain. I run two 2x4's joined together with 8" plywood squares every few feet. One end is a plywood square on end to saddle the butt of the log. The other end is adjustable 1x3. I use screws to attach my jig, careful not to enter the cut area, usually about 1/4" off. It has worked awesome for me. I usually cut 8 1/2 to 10 1/2 foot logs. When you are using the flat of the log as a guide remember to broom off the dust between cuts.
Everyone has to be somewhere.
Upper
Thanks Buggutz,got it...........Upper
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
Chuck White
Upper
Thanks Chuck,this new endeavor will surley cut into my hunting time....................Upper
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
isawlogs
When you secure the 2x4 onto the log, use screws, the first cut you need to be sure to be below them screws. If not funny noises will be heard from the chain and from you.....  :o   ::)
   Marcel
Upper
Thanks Isaw,I also plan to metal detect I hope I find more nails than gold.........Upper
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
isawlogs
If you do find nails,  after pulling them recheck the log with metal detector.  You'd be surprise to learn how many nails can be put inside a 1" circle .....   ::) ::) ::) :o
   Marcel!
   Marcel
PC-Urban-Sawyer
Quote from: Upper on October 15, 2015, 11:59:19 AM
If you find gold in them logs, things could really pan out for you  ;D ;D ;D
Herb
If there is gold inside of the log, you instantly know that it is Walnut and Very Valuable.   ;D
Nomad
Quote from: isawlogs on October 15, 2015, 11:36:45 AM
     Yeah...  No kidding! :D :D
Lucas DSM23-19
