Recent
469 Guests, 4 Users
sawmilllawyer, reedco, doc henderson, Jeff
Welcome to The 2024 Forestry Forum!
Do you have trees to grow? Logs to saw? A forest to manage? Chainsaws to fix? A sawmill to purchase or maintain? Timber related business to run? Lumber to dry? Trees or plants to identify? A cabin to build? Are you hungry and like FOOD?
Or would you just like to pull up a stump and visit with a friend?
If any of these and a multitude of other topics apply, then The Forestry Forum is the place for you.
What Will you Find on the Forestry Forum?
Pages: [1] 2 ... 40
Good day folks.
I'm hoping some of you who have done this in various ways will chime in with what works best and what hasn't.
I have a range road 36 mill and have replaced my cable crank with a 12v winch which has made life much easier. However I'm finding there is still a lot of variability in the travel speeds and I spend a lot of time trying to make tiny movements to get the mill head where I want it.Read More
0 Comments
Hi folks. I am looking at purchasing the Woodland Mills HM126 Woodlander. Wondering if anyone has any experience with this, or other Woodland Mills, trailer mounted band saw mills. I am leery about whether it is stable enough on the 4 trailer jacks and whether there is any sway at all when sawing...
Read More
0 Comments
I have been working on putting a power lift on my Timber King 1220, and ran into issue with gravity. I have tried a wheel chair motor, a rv electric jack motor and motor from a boat dock lift, all of which I had in my pile. They will all lift the head without problem, however they will not hold it in place, if I remove the factory hand crank and drive the lift directly. If I leave the hand crank in place, and use motor to turn the drive chain connected to crank, it (crank) binds up when trying to power down. Is anyone aware of a source for a 12-24v motor that would have a brake? or another way to stop the weight of head from causing it to drop freely.Read More
9 Comments
Hello all,
Have been looking into getting a portable winch. I know there are other options but the site here (steep hills and valleys, not great on equipment access) and my limited needs (I'm not looking to turn this into a business, this is all for personal and home use so not a lot of volume is needed)....
Read More
0 Comments
Had a guy drop off these 9 logs for me to saw. I'm pretty sure they are fir (Douglas or Balsam??) but if not please correct me.
He would like it sawn into 1x and 2x4's. I have not sawn fir before. All those knots look challenging.
I also wonder if because he just cut them and it is spring that there will be more sap. Should I be concerned? Does fir stain like Red Pine? Read More
16 Comments
Pages: [1] 2 ... 40
