Author Topic: Cutting construction lumber  (Read 2350 times)
Offline firefighter ontheside
  • I like trees.
« on: June 06, 2018, 06:08:05 PM »
Iím going to cut my first construction lumber tomorrow.  I have some big yellow pine logs that Iím going to cut with the plan to build my solar kiln with the wood.  Iíve reviewed Magicmanís sequence of cutting pictures that I saved and am going to follow.  Wish me luck.  This coincides with me having a tractor big enough to move the logs more easily.  Pictures tomorrow.....
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline SawyerTed
  • Summey Lumber Services, LLC
Re: Cutting construction lumber
« Reply #1 on: June 06, 2018, 07:14:41 PM »
Good luck!  That's part of what I'm doing this week.
That Magicman is an awesome resource among the many great folks here!
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher
Offline Skipper11A
« Reply #2 on: June 07, 2018, 12:54:12 PM »
A big tractor makes all the difference.  Good luck on your sawing!
  • I like trees.
« Reply #3 on: June 07, 2018, 04:41:18 PM »
I did it just like Magicman laid out in a series of pictures he posted.  It went perfectly.   I got 5 wide 4/4 boards and 50 2x4ís out of the 28Ē yellow pine log.  These are destined to become my solar kiln.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
« Reply #4 on: June 07, 2018, 09:52:03 PM »
What are you doing drying that SYP?  Don't you know you should be building with it while it's green, it'll just get harder if you let it dry?
Just kidding.  Nice looking stack of 2x4s...
Herb
  • I like trees.
« Reply #5 on: June 08, 2018, 08:07:55 AM »
The tree has been down for a long time and it was time to get it cut.  I stacked it close to where Iím going to build my kiln.  Hopefully Iíll get that built this summer.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline PA_Walnut
« Reply #6 on: June 08, 2018, 08:25:37 AM »
Can someone point me to MagicMan's sequence pix, please. Would like to check it out.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline Sixacresand
  • John and Nancy
« Reply #7 on: June 08, 2018, 08:35:57 AM »
Glad it did not have any stress and bend on you.
  • I like trees.
« Reply #8 on: June 08, 2018, 12:37:26 PM »
This is the sequence that Iím referring to by MM.  Go down a bit in the thread and youíll find the series of pictures depicting how to cut 2x4ís.
http://forestryforum.com/board/index.php?topic=82152.msg1252824#msg1252824
@PA_Walnut
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
  • I like trees.
« Reply #9 on: June 08, 2018, 12:38:25 PM »
No real stress.  Just had some wavy cuts when I got to some big knots.  No big deal. Iím not building a piano.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline Dad2FourWI
  • I love my job
« Reply #10 on: June 08, 2018, 08:23:54 PM »
That looks like some nice lumber!   ;D
We too are planning and prepping for a solar kiln... we are using the ideas from Jim Birkemeier - Timbergreen Farm... what plans are you using??
Thanks,
-Dad2FourWI
LT-40, LT-10, Bobcat T750 CTL, Ford 1910 tractor, tree farmer
  • I like trees.
« Reply #11 on: June 09, 2018, 09:21:33 AM »
Thanks.  I was kind of combining lots of ideas.  Mine will have no electricity, so I will use a solar powered fan.  I will make it on 6x6 skids.  I will have a 45į roof.  I will paint insides black after lots of insulation.  I have seen numerous parts of old walk-in freezers posted on FB.  Toying with using those.  I will have a large opening on back.  I will make removable panels that can be taken off and swinging doors to make the rest of the opening.  I want to be able to use forks to set a whole stack in there at one time.  When I get closer, I will look at some more plans like you mentioned.  It will be 6x12 to fit the longest lumber I can cut.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline samandothers
« Reply #12 on: June 09, 2018, 10:20:31 AM »
Looks great! Good job and I am sure you learned somethings.  I like you log loader.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #13 on: June 09, 2018, 11:13:13 AM »
   I cut a big red oak just like that yesterday. Cut 2- 2" flitches then a 5/4 board to make the math work right then cut 3-6" cants and turned them on edge and cut 2X6s out of them. I centered the pith in the middle cant with the heart check parallel to the deck so it did not show up in the boards. Worked great.
   As mentioned throughout these threads you need to know where you are wanting to go before you ever start your first cut.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #14 on: June 09, 2018, 11:29:10 AM »
It probably should be noted again....again that the framing lumber that I saw is all from SYP.  I have no idea how that would work out with other species.  I imagine that if you sawed a Yellow Poplar like that you might end up with a Yellow Banana.   ::)   Also not opening the faces so that the saw through is from either the hump or horn face could make a whack of "C's".   :o
  • I like trees.
« Reply #15 on: June 09, 2018, 01:37:07 PM »
That was a yellow pine species that I canít type into my iPad, because every time I do it puts a smiley face in the middle of the word.  What kind of tree is it?
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #16 on: June 09, 2018, 01:47:12 PM »
Loblolly. It probably would actually post the word because there is no space before/after the
Code: [Select]
lolIt's not your iPad.  You are typing the code for laughing.  :D
  • I like trees.
« Reply #17 on: June 09, 2018, 02:07:19 PM »
I wasnít using any spaces.  I just tested and youíre right.  Before I hit the button, it shows the smiley in the word, but when I post it shows it correctly.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline clintnelms
  • Woodmizer LT35HD
« Reply #18 on: June 14, 2018, 08:03:18 PM »
Pretty sure I saw a post of you discussing cutting logs with a hump and horn. If I recall you always start your cut with the horns on their side facing out, correct? Do you mind clarifying a little more what you mean above by not cutting through the hump or horn. Trying to images what you mean. Seems like that would be inevitable that you'd have to cut through them after a turn or two.
  • I like trees.
« Reply #19 on: June 14, 2018, 09:06:32 PM »
Thanks.  I had an idea and then someone else here had already made one, so I built what I had in mind along with some of his ideas.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
SYP Construction Lumber
Started by POSTON WIDEHEAD on Wanted
Last post June 28, 2014, 06:20:01 PM
by POSTON WIDEHEAD
Construction Lumber
Started by stumpy on Sawmills and Milling
Last post September 24, 2004, 09:50:15 AM
by Buzz-sawyer
Using sycamore for construction lumber
Started by sawyerkirk on General Board
Last post October 16, 2010, 05:18:19 PM
by paul case
Construction Lumber Bench
Started by Tree Feller on General Woodworking
Last post February 17, 2013, 05:34:44 PM
by Magicman
