TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Portable sawmill stolen  (Read 3161 times)
Offline DPatton
« on: June 08, 2018, 12:45:59 PM »
With my mill currently parked out at the farm about 20 miles from my home I have been nervous about someone messing with or potentially even stealing my mill. Now I do take some precautions to make it more of a challenge for someone to mess with or even steal it. I typically remove the band, remove the key, place a large log on the deck and centering the head over that log so it cant just be rolled off and place the loader arms in the down position.
Yesterday I decided to invest in a hitch locking system and get it installed on the mill for added security. I purchased a well known manufactures hitch locking set from TSC. It comes with a 5/8" receiver hitch locking pin for your receiver hitch, a 1/4" locking pin for the thumb flip device on your trailer hitch, and a locking mechanism that goes into the ball portion of a trailer hitch capping the end of the trailer hitch itself. These items are all keyed alike for convenience.
Like a dummy I didn't open it at the store and check its quality. After all it is a trusted name product. Sooooo I just paid my 60+ dollars and took the package to the farm so I could install it on my mill.
The pic below is of the two devices installed on my hitch.
 Now I knew going into this purchase that the locking bolt on the thumb device was only a deterrent for most thieves but I had high hopes that the capping device would make most thieves think twice. After installing it on my mill's hitch I'm unconvinced that the capping device is worth more than about two wooden nickels as I'm fairly confident that I could simply pry it off with a small 16" prybar or knock it off in three whacks or less with a 20 oz. claw hammer. Long story short my lesson learned. I guess I can always return it and get my money back.
More importantly my question to all of you here at the forum is what types of locking devices you guys have found that will make a 2" ball type hitch a much more difficult target for most thieves. I want to purchase a device that will offer a higher level of protection than this one. I also want to hear what you guys do that I'm not already doing to keep your mill form being targeted.
Thank you for your suggestions.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline Larry
Re: Portable sawmill stolen
« Reply #1 on: June 08, 2018, 02:00:19 PM »
I assume your 1600 is the same as my 2000.
Really nice not to have to walk around the tongue while changing bands.
Offline millwright
« Reply #2 on: June 08, 2018, 02:14:11 PM »
Thats one of the bad things about a portable mill. Sometimes their a little too portable
Online mike_belben
  • Pulp Friction
« Reply #3 on: June 08, 2018, 02:28:02 PM »
Cast yourself a mafia block with a big old dumptruck leaf spring stack upside down and rebar'd into it through the eyelets.  Chain to said mafia block with big kryptonite cable and a bolt cutter resistant lock.  Keep a sign on the block that says "Dear scumbag, there are 3 deer cameras pointed at my saw.  Can you find them before i find you?  The clock starts when i hear your grinder."
These days 18v cutoff tools make it possible to get through this but a cutoff grinder at night is a pretty odd sound.  I know id be pretty jumpy throwing a train of sparks and chop saw noise into the night, feeling like id be likely to get clubbed from behind as i worked.
Revelation 3:20
Offline Hilltop366
« Reply #4 on: June 08, 2018, 04:17:32 PM »
Reminds me of a story a friend told me about helping a older guy cut firewood one year, they were using a hand saw and my friend said " this would go a lot faster if I had brought my chainsaw" to which the old feller replied " this saw makes enough noise for were we are".
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #5 on: June 08, 2018, 04:36:48 PM »
18v bandsaws don't make much noise, and will cut hardened locks, or most anything else.
Offline Southside logger
« Reply #6 on: June 08, 2018, 04:38:24 PM »
Well - you have a 12V battery on the system, isolate/insulate any steel that touches the ground when you leave. Put a micro switch under the locking arm held by the new fangled anti theft devices you just bought, the switch goes first to a hidden kill switch, so you don't taze yourself, then onto a capacitor which is wired to the hitch of the mill.  When Sticky fingers Sam does break off the locking mechanism and lifts the hitch release so he can hook it to his truck the capacitor, which instantly dumped into the hitch, causes Sam to flop around looking like the "Don't Taze me dude" guy as he is the only path to ground.  Meanwhile your 12V battery recharges the capacitor so if he decides to try again, well this time his hair curls.  For sure have a hidden trail cam with video on it so the incident can go viral.
Woodmizer LT35 sawmill, KD250 kiln, BMS 250 sharpener and setter
Offline wesdor
« Reply #7 on: June 08, 2018, 05:52:04 PM »
I have a motorcycle wheel lock on my trailer. So far it has been safe, but several years ago someone stole my wood splitter one night. Never recovered it.
Hopefully the wheel lock will keep most casual thiefs away.
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #8 on: June 08, 2018, 06:04:55 PM »
   Similar thread I posted earlier with some suggestions.
Sawmill Security away from home in Sawmills and Milling
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #9 on: June 08, 2018, 06:14:34 PM »
I have an Abus motorcycle chain that fits through the mast and around the main tube, locking the head to the front of the mill. Cost about $250. But I haven't used it in years, just use a 5/16 chain and padlock instead when I leave the mill because I forget to bring it.  I don't often leave the mill only if it seems like a very safe spot.  I take the fuel tank with me. More worry about vandalism than anything else.  Actually I don't worry about it at all.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline sawguy21
« Reply #10 on: June 08, 2018, 06:38:45 PM »
If thieves want it bad enough they will find a way to defeat security systems. You could block it and take the wheels with you, I see a lot of rental equipment on job sites immobilized this way. The Denver boot The Denver Boot is used by law enforcement agencies and seems pretty effective. Do what you can and carry adequate insurance.
Online WV Sawmiller
« Reply #11 on: June 08, 2018, 10:10:43 PM »
Southside
   I am sure it would be a great video but, unless the voltage was enough to totally incapacitate him or set off enough highly audible alarms in the area, I would lay you odds that the video would, after the hilarious initial electrical shock, also show Sticky fingers Sam thoroughly destroying your mill.
   Not to say any measure we use to thwart a theft may also prompt vandalism to the mill. I figure we do what we can to just make it so inconvenient and so much effort SF Sam just decides it is not worth the effort, time and risk.
   I worked closely with our security manager in western Africa hardening our homes there to prevent theft and violence to our employees and the main concept we followed was to make it easier to break in somewhere else.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #12 on: June 08, 2018, 10:16:38 PM »
Some have switched the 2" ball hitch to a pintle hook hitch!
That would be a deterrant, but not 100% fool-proof!
About two years there was a Forestry Forum member who had his "virtually" new mill stolen from a secured building, behind a locked gate!  I don't believe the mill was ever recovered!
I don't think there are any "absolutes", just deterrants!
~Chuck~
I LOVE MY SAWMILL
« Reply #13 on: June 08, 2018, 11:29:04 PM »
WV - not arguing your point, but 12V through a capacitor can lay you on the ground for 10 minutes and make you pee your pants.  Basically it's the technology in a taser.  If he's not going to walk away after that, short of being there you are not going to stop him.  A pepper device would be as effective and non lethal as well.  If a guy is going to steal from me, he is going to have to do it the old fashioned way - he is going to earn it is my philosophy.
A guy could even add a remote cell notification device, they are used a lot on irrigation systems both to let you know something is wrong and if a theft is happening given the amount of copper wire many have integrated into them.
Offline Skipper11A
« Reply #14 on: June 09, 2018, 12:59:29 AM »
DPatton, you know you have to take the sawmill home with you, right?  Are you asking for permission to keep it 20 miles away from you?  You're nuts. If you leave it on the farm alone it will be stolen.  End of story....but you already know the end of the story which is why you are taking "anti-theft" tactics.  Just take the sawmill home with you, every time!
Online WV Sawmiller
« Reply #15 on: June 09, 2018, 01:12:38 AM »
Southside,
   I understand and would love to see even more severe consequences for thieves but I was just offering an opinion abut human nature. I like the member's avatar statement about a backhoe and 40 acres but I digress. Most places I leave mine it is very secure - but that does not stop me from worrying.
Offline Alberta Wolf
« Reply #16 on: June 09, 2018, 02:08:13 AM »
Sorry to hear about the theft of mill :(.Park the mill in the grass and leave some harrows laying teeth up.You'd find them fast cause they would have 4 flat tires.Police would say that is against the law.But it also helps harrows from sticking in the ground and it protects them also. ;) But don't forget you put them in front of the mill.I know thieves have more rights than we who looses things.So invest in a backhoe also.It deters them when they seen a sign reading " I own a backhoe and know allot of place for you thieves...."Enuff said . ;D I also gotten things stolen to avail cause Tim Hortons is more important than finding them scum.So I know how you feel.Signs and harrows laying ing the grass works wonders. ;) :D.
Offline Satamax
« Reply #17 on: June 09, 2018, 05:53:32 AM »
I don't know if it could be used here.
But one real pain in thieves attempts is the master hockey puck padlock and hasp.
Even more if you can weld the hasp.
https://www.peerlessdoorlocks.com/roundpadlocks.html
There is other creative ways to use these too.
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #18 on: June 09, 2018, 06:08:23 AM »
Put the hitch in the truck when you go.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #19 on: June 09, 2018, 08:17:26 AM »
I regularly remove locks at a mini-storage facility and my 18v grinder with a cut-off wheel will easily take care of any lock or security device.
I regularly leave my sawmill at locations and have never worried about it.  Ain't nobody gonna bother to steal this sawmill.  If they do it would be easier for them to saw the log first.  :D
Reward for stolen Peterson sawmill
Started by MIKO on Sawmills and Milling
Last post August 12, 2015, 06:25:00 PM
by beenthere
exclamation
A Stolen Sawmill: A happy ending and justice done!
Started by Mooney on Sawmills and Milling
Last post February 05, 2012, 02:03:43 PM
by jtmccallum
Portable Sawmill Special Deal - SAVE 10% on your Sawmill!
Started by HSV on Peterson Portable Sawmills
Last post March 10, 2015, 10:34:01 PM
by jamieotter
Why did you buy a portable sawmill?
Started by rockman on Sawmills and Milling
Last post January 31, 2012, 08:16:18 PM
by rockman
