Author Topic: My new 2011 Timberking 2000 Diesel  (Read 1380 times)
Offline maderahardwoods
  • California Sawyer
    • Madera Hardwoods
« on: June 11, 2018, 12:53:45 PM »
Well it finally happened! I drove up with the family to pick up a 2011 Timberking from Gerard of Joseph's Juniper in Burns, Oregon. Joseph runs an interesting operation harvesting Juniper trees in the Oregon high desert.
The mill is a 2011 TK2000 with 32hp Kohler Diesel (and setworks) as well as the optional dual axle.  The motor was replaced under warranty a few years back and has about 200-300 hrs on it. I cut a few logs before handing over the payment, all of the hydraulics worked smoothly and efficiently.
The mill was serviced religiously but needs a good pressure washing and a few consumables.  I was very happy by how she towed, no drift, even at higher speeds.
We got home Sunday afternoon and I wasted no time getting her parked and cutting a log up.  She went through a redwood and walnut like butter, I am currently running a 7 degree blade (that is what was included).
Timberking transferred the SN over to my name,  I must say they have great customer service! They are sending me a hat, manuals, DVD, as well as the Ultra and Ultra Max blades I ordered.
There are a few modifications/repairs I would like to perform on the mill:
Deep cleaning
Verify blade tracking and belt tension (any tips would be appreciated), any specific model of belt tension tool I should buy?
Lube all points
Move ignition and warning light box to operator control center
Convert to LED lights!
Add tachometer
Add a remote throttle, this may be sooner than later!
Fabricate 1/4 plate wheel fenders, I would like to be able to stand on them for water fills and fuel fill-ups
I paid $28,000 which I feel is fair since the mill had the motor replaced.  I did a lot of research and even older WM and TK's are fetching good money currently.  I am excited to learn the machine and learn how to use the Setworks controller for dropping the head!
Offline samandothers
Re: My new 2011 Timberking 2000 Diesel
« Reply #1 on: June 11, 2018, 01:03:58 PM »
Congratulations on your new mill!  You will have fun learning how to use it and doing the modifications.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: June 11, 2018, 01:16:18 PM »
I extend my hardy Congratulations to you (and your family).  It also sounds like you are taking the right steps toward learning and maintaining the "new" sawmill.  8)  I will be anxious to see some fresh sawn lumber.  :)
Offline reswire
« Reply #3 on: June 11, 2018, 01:20:11 PM »
Congratulations!  Good things come to those who wait, and shop wisely.
LT 40HDG 35, JD 5205, some Stihl saws, 15 goats, 10 chickens, 3 Chessies and a Weiner dog...
Offline Larry
« Reply #4 on: June 11, 2018, 07:59:57 PM »
Good choice on the mill.
I fabricated a remote throttle using a HF winch motor.  It has worked well for the past 8 years.  Other members have used a linear actuator which is really the best method.  If the TK remote throttle been available at the time I would have went with it.
Search is your friend and can find many modification tips, a lot done by me.  I consider the 12" hydraulic cylinder on the two plane clamp to be one of the best.  Really makes edging on the mill a whole lot easier.
Offline DPatton
« Reply #5 on: June 11, 2018, 09:39:30 PM »
A 2011 TK2000 with a diesel....I think you got a lot of sawmill for the price! Congratulations. Was I seeing double in that second photo?
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline sawmilllawyer
  • Ride hard, die free.
« Reply #6 on: June 11, 2018, 09:50:19 PM »
As in two mills?
Stihl MS-361, MS-460 mag, Poulan 2150, 2375 Wildthing.
Offline DPatton
« Reply #7 on: June 11, 2018, 09:58:11 PM »
As in two mills?
Yes, two TK mills side by side.
Offline xlogger
« Reply #8 on: June 12, 2018, 05:40:31 AM »
I think you got a good buy. TK is great to work with even if you got a used machine. Congratulation
  • California Sawyer
    • Madera Hardwoods
« Reply #9 on: June 12, 2018, 09:25:11 AM »
No sir, the previous owner has twin TK2000's, one was a 2011 and the other was a 2012.  He might sell the second and purchase a brand new mill from Timberking.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #10 on: June 12, 2018, 11:05:37 AM »
I've seen your sawmill and have admired the operation there in Burns. Juniper is very dirty & messy stuff to cut so I'm sure the mill could use a deep cleaning. Congratulations and have fun!
1992 LT40HD
  • California Sawyer
    • Madera Hardwoods
« Reply #11 on: June 12, 2018, 11:24:43 AM »
Thanks for the warm welcome!
So I was up last night pondering how to add a linear actuator to control the throttle from the operator station.  The photos below show that there are no mounting bosses or brackets I could pick-up from.  It also appears that the throttle cable is missing a mounting bracket, it may have been lost during the motor swap.
I think the best option is to swap the vernier cable head with a lever style cable throttle, specifically the Oregon 60-522.  I could then attach the linear actuator with a simple clevis to the throttle lever.  I am totally open to any other idea!
Offline CX3
« Reply #12 on: June 12, 2018, 11:28:35 PM »
What is the purpose for adding this throttle thingy majig?
John 3:16
You Better Believe It!
Offline ladylake
« Reply #13 on: June 13, 2018, 06:25:06 AM »
  The throttle is so you can slow down or speed up the engine from the end of the mill where the controls are.  Whats that Kohler diesel doing on there, I thought TK ran Kubota . A mill by me has a Kubota on his TK 2000.  Steve
Offline DPatton
« Reply #14 on: June 13, 2018, 09:02:38 AM »
 Steve,
The OP said the original owner had a problem with the original motor. The Kohler is a replacement motor.
Offline Will_Johnson
  • Sponsor
  • Inveniemus viam aut faciemus
    • www.timberking.com
« Reply #15 on: June 13, 2018, 01:30:37 PM »
Currently all TimberKing diesel mills carry Kubota diesel engines.
This mill was made in 2011 during a time when we were using Kohler diesel engines.
Offline ladylake
« Reply #16 on: June 14, 2018, 06:41:12 AM »
 Thanks for straightening that out Will. If that Kohler which is the same as Lombardini which don't seem to last I'd replace it with a Kubota  or maybe Yanmar no matter what it takes.  I think a lot of the small diesels use the same motor mounts.  Steve
***New Here! Just got the TimberKing 2000***
Started by kgbond on Sawmills and Milling
Last post May 15, 2012, 12:24:16 AM
by ForestMan
Setworks Timberking 2000
Started by red pine on Sawmills and Milling
Last post November 23, 2013, 11:41:00 AM
by red pine
Timberking 2000 debarker
Started by lumberman1955 on Sawmills and Milling
Last post January 01, 2016, 08:22:54 AM
by sandsawmill14
drip system for timberking 2000
Last post June 06, 2012, 05:10:55 PM
by vt k-9
