Author Topic: how do you clean your thin kirf sawmill blades?  (Read 8831 times)
Offline Robert Long
  • winner of WM Personal Best "GRAND CHAMPION" Cat. 6
    • www.portablesawmill.ca
« on: January 18, 2007, 08:06:28 PM »
 >:( I just spent most of my evening cleaning sawmill blades before sharpening them....
When out cutting custom work I cut logs of many spiecies and when blades get dull I just replace them and move on.....but when I get home I spend lots of time scraping off the hard sap with a paint scraper before putting them on the sharpening system.
What do YOU do?
 :-\  Robert
Re: how do you clean your thin kirf sawmill blades?
« Reply #1 on: January 18, 2007, 08:10:07 PM »
I run the blade lube full bore (water) until the blade is clean.  Then I take it off.  :)
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #2 on: January 18, 2007, 08:25:38 PM »
 If the dull one IS clean, wipe it down with an oily rag, before folding.
Offline treebucker
  • God 1st.
« Reply #3 on: January 18, 2007, 08:40:09 PM »
Run it full speed with the water off then spray/wipe it with your favorite brew (WD40/diesel/kerosene/etc.) before removing it.
Last night I lay in bed looking up at the stars in the sky and
I thought to myself, "Where the heck is the ceiling?!" - Anon
Offline Brad_S.
« Reply #4 on: January 18, 2007, 08:46:18 PM »
I run a diesel oil drip and do the same- clean it before it comes off. Sometimes I may need to open the drip to saturate the blade and then hold a stick to the blade if there is a heavy, gummy buildup.
Offline Larry
« Reply #5 on: January 18, 2007, 08:47:53 PM »
Your band should be clean while your sawing...if you have a build up of sap your probably not running nuff lube when sawing.
But if you get sap build up, do as Tom suggested.
And if you have a build up on bands waiting to be re-sharpened just spray them down with oven cleaner and wipe off the sap in bout 5 minutes.
And don't think you can use oven cleaner on carbide table saw blades...it's lye and weakens carbide.
« Reply #6 on: January 18, 2007, 08:57:01 PM »
Quote
  Never knew that, Larry. Thanks
Offline Robert Long
« Reply #7 on: January 18, 2007, 09:01:23 PM »
Thanks Larry
Now to have a carbide band saw woodmill......
Robert
Offline Robert Long
« Reply #8 on: January 18, 2007, 09:10:29 PM »
Thanks for the suggestions all......but :-\
Won't the blade run off the pulleys with a lube like 10w or kerosene added and what can be added to the water to help with sap build-up?
Robert
Offline arj
  • I need to edit my profile
« Reply #9 on: January 18, 2007, 09:15:30 PM »
I use carb cleaner before I take the blade off the mill, just a lite spray
and it scraps off easily.
                                      arj
Offline woodmills1
  • the truth shall set you free
« Reply #10 on: January 18, 2007, 09:16:54 PM »
use 50 50 diesel/bar oil all the time from squirt bottle.  I run it on every blade till clean before removing.  Got tired of scraping.
Offline Minnesota_boy
  • Some like 'em short, but I prefer looong!
« Reply #11 on: January 18, 2007, 09:19:28 PM »
You can add a bit of dish soap to help with the sap or you can do like me and keep the blades really sharp and not run lube at all (well hardly).  ;D
Disclaimer:  There are some species that even I have to run lube to keep the blade from gumming up.
Offline ohsoloco
  • Can we stay outside and play in the sawdust?
« Reply #12 on: January 18, 2007, 09:23:20 PM »
Robert, when I'm cutting something that's really sappy like spruce, pine, or tamarack I mix a few ounces of Dawn dish soap in with my water.  Last year I cut some red pine for someone that had them stacked for over a year.  I figured they'd be easy to cut....y'know, maybe less sappy since they sat for a while  ::)  I couldn't make more than one cut without the blade getting all gummed up and then taking a dive in the cant.  Put some dish soap in the water and it cleared right up  ;)
Minnesota_boy beat me to it  :D
« Reply #13 on: January 18, 2007, 09:24:34 PM »
For the most part, all I run is water in varying amounts.  Sometimes 1/3 cup to the gallon of dish soap like palmolive.
Offline getoverit
  • freeing trees from silence
« Reply #14 on: January 18, 2007, 09:25:23 PM »
PineSol mixed with the lube water helps keep the blades clean when you are sawing pine. With other woods like sweet gum, I just run an extra good stream of water while cutting to keep the blades clean.
Side note:
If you mix dish washing detergent and water for lube, it can cause the water jug to fill with foam and you will be hours trying to fill it up with a hose the next time you fill the tank. Dont ask me how I know this :D :D
Offline woodmills1
« Reply #15 on: January 18, 2007, 09:27:38 PM »
old pine may be the worst for sap build up.
Offline ohsoloco
« Reply #16 on: January 18, 2007, 09:30:14 PM »
Lots of old pine in the log pile  ::)
Offline Robert Long
« Reply #17 on: January 18, 2007, 09:32:33 PM »
Hey...Minessota-boy
May be we should talk about sharpening to solve the other problems?
Robert
Offline Brad_S.
« Reply #18 on: January 18, 2007, 09:35:16 PM »
I don't know if it's the same with a WM, but if too much lube throws the blade on mine, it's a sign the wheel belts are way past worn out. A good crown on the wheel keeps the blade on no matter how much lube is applied.
Offline rewimmer
« Reply #19 on: January 18, 2007, 11:11:35 PM »
Hello Robert,
I saw a lot of the gummy pine here in Virginia. We use a lot of pine-sol in our water and see a lot of bubbles. We never have sap on the blades when we change them. Something else we have had problems with is sap on the rails and under the guards. I had a brain storm a few weeks ago and cleaned the rails and guards real good. Then sprayed the heavy with PAM and have gone 3 blade changes with no sap on rails. I just wipe the rails with paper towel and spray on more. The buildup under the guards just wipes with a paper towel also. Sam's has the best price on both items.
Robert in Virginia
keep blades clean
Started by locdogg on Sawmills and Milling
Last post May 21, 2012, 09:43:07 PM
by kelLOGg
Making the Most of Thin-Kerf, Narrow-Band Blades
Started by Bibbyman on Sawmills and Milling
Last post June 13, 2003, 06:23:21 AM
by Bibbyman
Larch, how do you clean your blades?
Started by Satamax on Sawmills and Milling
Last post August 19, 2017, 01:53:17 AM
by Satamax
Clean Blades Stay Sharper, maintain set, and Cut Flatter Lumber w/o soap
Started by prittgers on Sawmills and Milling
Last post September 20, 2014, 12:32:39 AM
by YellowHammer
