Author Topic: valley machine works edger  (Read 8709 times)
Offline snowmobile95
« on: December 25, 2010, 10:28:13 AM »
Hi, to all. I am new to this forum, and this my first post.
I recently stumbled opon a valley machine works edger at a local salvage yard for $100.00  which seems to be in very usable condition, with the eception of a missing motor. It had an electric motor on it that looks like it was just removed prior to entering the salvage yard. I want to install a gas or diesel one on it. I spent many hours online searching for info on it, but found nothing, other than a very small picture of one up for auction which looks like the one I have. Mine does not have a model number listed on the tag just a vin# and ser#. The one up for auction states it is a junior edger, model JES2X24.
I compared it to the woodmizer edger (pictures) and it seems to be identical to the one I have.
Does anyone no anything about this unit? What size pulley would I need for the motor? Or where I might be able to locate an operaters manual?
Any advise would be greatly appreciated.
THANK YOU  :
Offline Bibbyman
    • Warden Sawmill
Re: valley machine works edger
« Reply #1 on: December 25, 2010, 10:56:39 AM »
Welcome to the Forum!
Does it look anything like this Wood-Mizer edger?
If I remember right,  the old model Wood-Mizer edger (not the one in the picture) was made in Canada by Valley.
Putting an engine on it should be no big problem.
Sawing since '94
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: December 25, 2010, 11:41:23 AM »
I have an old Sawmill and Woodlot that has an advertisement for a twin blade exactly like that one Bibbyman, only it was made by Valley.
« Reply #3 on: December 25, 2010, 08:01:45 PM »
Yes it looks identical to your machine. With a few small differences. There is a black arm on side opposite the engine between the 2 upper roller bearings on yours, but not on mine. And mine has 3 shafts exposed on the motor side, where yours does not. Looks like there was a cover over them at one time. And the leveling legs (woodmizer) on yours are the same as my LT20, but the ones on my edger are a flipup crank trailer type jack stand.
Looks like I will be contacting Woodmizer for an operators manual for your model, as I beleive it would work. Unless they have one for mine.
thanks, Bibbyman and Dave
your help is very much appreciated.
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #4 on: December 25, 2010, 08:59:22 PM »
Wood-Mizer carries the following parts for the Valley edger:
Item Description Valley
Part No.
Wood-Mizer
Part No.
1 BLADE, 18T HARDWOOD JE2X24041 012967
2 BLADE, 8T SOFTWOOD JE2X24117 013000
3 KEY, BLADE SHAFT JE2X24186 018492
4 MANUAL, VALLEY EDGER OPERATORS N/A 012985
5 SCREW, LOW HEAD SOCKET HEAD JE2X24179 018493
Merry Christmas!
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
« Reply #5 on: December 25, 2010, 09:25:17 PM »
thanks, Marty
Leon
Offline argyle1
« Reply #6 on: December 25, 2010, 09:31:07 PM »
$100.00----holy wow'what abuy
website is www.valleymachines.com---but i couldn't bring it up--listed ph.# is 506 575 2231
it could be that they went broke as I know their pellet machine manufacturing department did----a guy down the road here gave them over a million bucks to build 2 pelleters, then they went broke, he wound up owning the patents and still had the machines built. He.s just starting production now, after 2 yrs---good thing he had deep pockets
once you know the rpm of the engine you will use and you desired arbor speed, the pulley sizes will be easy
« Reply #7 on: December 25, 2010, 09:47:53 PM »
Thats as far as I got to. Valley looks like it is up for sale.
thankyou
Leon
« Reply #8 on: December 25, 2010, 09:52:21 PM »
will be posting pics tommorow.
Offline Meadows Miller
  • Location: Find a Job You Love & You Will Never Work Another Day In Your Life
  • The Walkabout Sawyer
« Reply #9 on: December 25, 2010, 11:01:36 PM »
Gday
And Welcome to The Forum Leon  ;) ;D 8) 8) I take it you already have a mill if your adding and edger  ??? I have always liked the look of the valley edgers when I use to get the woodmizer catalogs  ;) with the the pulley sizes you would have to workout the rpm the saw shaft needs to spin at and match that to the type of motor your going to run  ;) all in all if they do go out of action you could most likely fab any replacement parts you would need edgers are pretty simple saw units once you get down to it Mate  ;) ;D 8)
Regards Chris
4TH Generation Timbergetter
« Reply #10 on: December 26, 2010, 12:25:11 PM »
I have added pictures of the eder to my profile. But was not able to post any, because I am unable to create an album. Spent many hours this morning with lots of frustration and no success.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #11 on: December 26, 2010, 12:53:38 PM »
A hundred bucks is pretty DanGed cheap.  Buy it before someone else does  :)
Offline beenthere
« Reply #12 on: December 26, 2010, 01:27:26 PM »
Can we help with the pics? Did you go to your profile and set up your gallery?  (not sure if that is what you meant when you said "unable to create an album").
And check out the java test that Jeff just posted.
http://www.java.com/en/download/help/testvm.xml
None of pic posting should be difficult...just sometimes don't know how really close we are when it feels we are no-where close. :)
Offline Bibbyman
    • Warden Sawmill
« Reply #13 on: December 26, 2010, 02:13:01 PM »
'Nether words,  It's pretty easy once you figure it out.  ;)
Sawing since '94
« Reply #14 on: December 26, 2010, 02:46:35 PM »
the problem i'm having is that the image archive button that's supposed be clicked in order to start an album does not appear anywhere. at least that is what it is telling me to do in the help menu.
Offline r.man
« Reply #15 on: December 26, 2010, 03:17:38 PM »
Leon, there are pictures at your profile that appear to be a motorless planer. Welcome to the forum.
Offline Bibbyman
    • Warden Sawmill
« Reply #16 on: December 26, 2010, 03:20:13 PM »
I'm not the expert at this but maybe if you poke the Forum Extras button above.
It looks like this ==>
And then go to the "Photo Galleries".  You may be able to start you album there.
Good luck...
Sawing since '94
    • My homepage
« Reply #17 on: December 26, 2010, 05:32:12 PM »
The pics in his profile are of the Valley edger in question. Looks almost identical to the W-M ED26 we have at work.
Offline red
  • we will never forget
« Reply #18 on: January 02, 2011, 10:15:13 PM »
I will give you $200   :D
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline papow22
« Reply #19 on: January 04, 2011, 01:14:15 AM »
Same goes for me,For a second there "I" thought I was the only one that did everthing ?????????? ::) :-\ :'( eh.Then I was  :o to see I was not alone :D.I hope to find a answer soon.I even redone the java update.I don't know if i'm  :P in the words rite >:(.I only got to add some photo's that I had to my profile,without sucess to add a album or creat one. >:( >:(.
Lives to do sawdust,run a trapline,hunt big game,live life to it's most.Got 4 mills a circle mill,(2 band sawmills) Norwood's 2000, Trim Saw,Beam Machine (chainsaw mill).
Valley Machine Works Edger
Started by lawnsbylane on Sawmills and Milling
Last post March 23, 2014, 08:11:31 PM
by Peter Drouin
question
How do I source replacement blades for a Valley Machine Works Junior Edger?
Started by sallyb on Sawmills and Milling
Last post June 26, 2017, 06:53:30 PM
by sallyb
berlin machine works molder
Started by beav39 on General Board
Last post April 04, 2009, 11:07:46 PM
by sawdust
Log valley
Started by cloair on Timber Framing/Log construction
Last post December 19, 2007, 06:58:42 PM
by cloair
