What should I do with these
Started by goose63, October 09, 2016, 06:07:45 PM
goose63
Some nice Hackberry should saw them and into what or leave them untill some one want's the lumber from them whiteflag_smiley
goose
thank you to all the vets
fishfighter
Don't know. Can you get a picture of the bark? Reason, just want to see if it is the same I have here in the south. Always was a trash tree around here. Not even good for fire wood. :D
goose63
fishfighter up here it's DanG good fire wood I will get a picture of the barck in the morening for ya
goose
ozarkgem
Leaved it lay for a yr and spalt.
Kcwoodbutcher
I let most of my hackberry spalt. It's the only way I make money with it. Those logs are too big to spalt anything but the outer surface and ends. When I work bigger logs for spalting I'll cut it and then dead stack it for several months. This way I can get a more even spalting. You may have to pry the boards apart with a crowbar but it seems to work.
My job is to do everything nobody else felt like doing today
ozarkgem
Quote from: Kcwoodbutcher on October 09, 2016, 09:15:02 PM
What size range do you leave whole to spalt? I got some to cut and plan on leaving them stacked. When you cut them are you sawing them into boards or just spliting the log and restacking them together
fishfighter
Quote from: goose63 on October 09, 2016, 06:57:31 PM
Heck, as firewood, it doesn't have any BTU's and goes up in a flash. Just a waste of time splitting and stacking. :D I have way to many hardwood trees for firewood. ;D
sandsawmill14
we cut it into rr ties  ;D but far as fire wood ours burns so hot it will melt a stove down if you dont mix it with something and pops worse than hickory but it does burn up quick :) i like it in cold weather though you know when its 20-25 degrees ;D
ladylake
Up here cold is -20 to -25 or worse.  Steve
sandsawmill14
Quote from: ladylake on October 10, 2016, 07:38:03 AM
:o :o :o my coffee would freeze up there :o :D :D :D
fishfighter
Quote from: sandsawmill14 on October 10, 2016, 07:21:47 AM
Heck, we might see about 5-7 days of winter at those temps. :D
goose63
Quote from: sandsawmill14 on October 10, 2016, 07:41:41 AM
You guys better drink the coffee fast
fishfighter here is a picture of the bark and end grain
It has a red tint in it
goose
LeeB
Doesn't look like the hackberry I'm familiar with.
sandsawmill14
Quote from: LeeB on October 10, 2016, 01:25:10 PM
x2  i will look and see if we have any on the yard in the morning and if so i get a pic of ours :)
fishfighter
Not the same here. Let me go get a picture.
This is what we call a hackberry.
Leaves
Tom the Sawyer
Around here, most of a hackberry log will be white or a bit yellowish with a small, darker center.  The bark is warty in both hackberry and sugarberry.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
sandsawmill14
Tom that sounds like what im used to seeing the bark is smooth as beech with warts all over :)  some logs are just about covered with warts and just small patches of smooth bark while others are almost completely smooth with just a few warts around the butt end of the log :) the inside looks as you described :)
fishfighter
Yep, that is what we call hackberry as in the pictures I posted.
goose63
Now I'm not sure if this is Hackberry.
But this is
This one has been down for a year
Still standing
and the leave's
What ever the wood is  it's sold I think showed pictures to a wood worker and he love's it
goose
Kcwoodbutcher
Quote from: ozarkgem on October 10, 2016, 06:00:43 AM
I just slab them at 9/4 then dead stack them  I can edge them or resaw them later as needed.
5quarter
Hackberry has an irregular heart,  but the sapwood is very white. I quarter saw a lot of it and use it for drawer boxes. If you want the white to remain white, you need to saw it and get it drying fairly quick, otherwise it will grey stain. once that happens, its only good for building things that get painted. The standing tree in your pictures is definitely hackberry. The one on the trailer is something else.
Fishfighter...that doesn't look like the hackberry we have here.
Blue Harbor Refinishing
goose63
This is 1 of the 3 log's that were on the trailer not sure what it is but the wood worker wants it
goose
fishfighter
Quote from: 5quarter on October 11, 2016, 11:36:22 PM
Some trees have a lot more warts on them then others. The one in the picture had very few warts. Most of the hackberry trees here grow on fence lines or at the edge of woods.
sandsawmill14
the pic fish posted is  southern  hackberry without question  :) but i dont know how many kinds of hackberry there is ??? could be like red oak and be 50 different kinds  :D :D :D
5quarter
Quote from: sandsawmill14 on October 12, 2016, 07:54:41 AM
I figured it was something like that...thanks.
