Np trans
Started by jd540b, August 06, 2014, 08:11:15 AM
jd540b
Can you replace shift forks without pulling whole trans?  Just through top cover?
Neilo
What model NP are you talking about?
You can take top cover off with shift forks on a NP441 as fitted to a TJ 200 D series skidder.
logman81
You should be able to access them through the top cover. Those were suppose to be rebuilt not that long ago from what I was told.
Precision Firewood & Logging
jd540b
Got it fixed yesterday.  Went in through top.  Was just a bit worn and sticking in third gear.  That  230 is a super easy skidder to work on.
logman81
Yup they sure are glad you got it fixed.
