Find a Sawyer Link ??
Started by DR Buck, October 08, 2017, 10:04:23 PM
DR Buck
I believe I've gone blind.     I cannot locate the "Find A Sawyer" link that used to be on the top of the forum page.  smiley_headscratch
I was going to send someone to that link as they need a sawyer in the Richmond Va area.  However, I have nothing to send them to.
WV Sawmiller
   Give your seeing eye dog an extra treat.
    It is under the Extras button on top. Click, select find a data base, select Portable band mill under services, click State and select from the drop down, then click search on the bottom left and you should get the desired results.
It's been where it is now for 5 years.
