Makita mortiser technique
Started by vtframer, September 27, 2014, 11:19:26 AM
vtframer
Hi all - I'm getting ready to cut my first through-mortise (9" total depth) with the makita chain mortiser.  I've heard that it can be tricky and if you're not careful the chain will catch and slam down against the stop.  Is there a good technique out there for doing these without that happening?
Thanks!
Jim_Rogers
Half way from each side is the normal set up. That prevent the risk of breaking off your dept stop bracket.
And it usually helps to align the mortise correctly.
At least that's what I do.
Jim Rogers
logman
I always loosen the depth adjustment so it can't slam against it and break it.
LT40HD, 12' ext, 5105 JD tractor, Genie GTH5519 telehandler
M&K Timber Works
vtframer
Thanks guys!  Appreciate the advice :-)
