tire repair ?
Started by Pa woodchuck, November 22, 2014, 10:49:02 AM
Pa woodchuck
I have a skidder tire that had a piece if rebar stuck in it.  Would it be safe to just place a patch inside the tire?  Any other low cost suggestions?
sshier
Really heavy rubber patch and tube it that's what I'd try before getting a replacement I'd use a really heavy patch
Jhenderson
Go to a tire repair shop that specializes in off road repair. They will have a patch that's about 1 foot square and 12-20 ply. That will hold if the damage isn't too close to the bead. Really nasty damage needs to be vulcanized, which is done in a specialty shop the tire man deals with.
Maine logger88
Yup definatly can be fixed I even bolted a thick boot inside one of my tires seems to be holding up well. With new tires at 2500$ anything to get a little more life out of them
I used carriage bolts to bolt it in facing out then cut the bolt of flush with the nut
chester_tree _farmah
Yankee ingenuity at it's best...
254xp
C4B Can-Car Tree Farmer
Ford 1720 4wd loader hoe
dutchman
In western Pa.
Had a rear tractor tire valcanized by Good tire off I 80
Knox.
The tire shop is just off Rt 66 at Kittaning.
thenorthman
Have a 4" or so gash in one of mine, been there about 2 years, boot it and either patch the tube or get a new tube.
Anymore I just patch the tubes and keep going, costs about $150 to have the boot done, and really if the hole is less then 1" I would just get a large patch on the tube and not worry about it...
well that didn't work
RayMO
Had a metal fence post through one of mine and a boot and tube has held fine for over 6 months.
Father & Son Logging and sawing operation .
bushmechanic
I've repaired hundreds with crusher belting and carriage bolts like Maine Logger88 has shown there. But I will suggest that you taper the edges of your boot because if not it will chafe your tube. I use a flap disc on the grinder and oh yes a dust mask .... definately a dusk mask.
Pa woodchuck
Thanks for the ideas guys. I went with a heavy patch and new tube, actually 2 patches because when I got the tire off I found a bullet inside it.
Jhenderson
That'll let the air out, sure enough.
KyLogger
I need to fix a tire on the 440B. Have changed lots of farm tractor tires, have a screw type bead buster and all the tools. But have never tackled a skidder tire. Are they doable or should I call in the pros?
I only work old iron because I secretly have a love affair with my service truck!
Maine logger88
A lot harder than a farm tractor but doable for sure even with just wedges a hammer and big tire irons. But a loader works about the best to break them down.
OntarioAl
Kylogger
If you can maneuver the tire so that you can use your blade and a block of wood breaking the bead is no problem.
Al
Al Raman
treeslayer2003
Quote from: KyLogger on November 23, 2014, 09:19:29 PM
them little tires ain't bad..........i don't mind 28s to bad.......34 just to much lol. a grapple will break the bead easy, just got to be care full.
yer gonna need two long tire irons.
