Need advice
Started by Pjames, May 19, 2018, 06:12:21 PM
Pjames
What kind of finish do I need to use on an outdoor cedar bench??
caveman
I would use boiled linseed oil thinned with mineral spirits.
Caveman
On oil finish will be easier to maintain as it soaks into the wood.  Varnish is only a film coat and it will peel over time.
Pjames
Thanks for the advice I was leaning toward polyurethane but I have never finished outside furniture before it is just something I put together for my wife actually she is supposed to do the finishing?
Ljohnsaw
I came from a big family (7 kids).  For our dinning table, my folks picked up a 6 or 7 foot diameter picnic table (redwood) with 5 2-seat benches.  They finished it with a really nice varnish.  My Dad's first big paying job was as a varnish cooker so he knew varnish.  It was spectacular.  It stayed inside for years.  We moved to NY and it was outside 1 summer and the varnish cracked and peeled.
John Sawicky
Polyurethane for a dining table inside. It might not be the "best" finish, but it will handle the moisture / spills / kids better than the fancier finishes. Outside, the UV sunlight and weather will break it down over time, and it just ends up looking ugly and flaking.
An oil finish is better when it's outside. It will also break down over time, but you just re-apply it as needed to keep the wood looking good. Make it an annual "spring cleanup" thing and cedar will last and look good for years.
Pjames
Thanks for the advice will try to add picks
9
YellowHammer
Poly will shed like a snakeskin in a few years, but any kind of oil is good.
Cedar doesn't care, it will last a long time the way it is.  Hit it with a pressure washer every once in a while, it will turn bright red again.  Cedar has a lot of natural oils, and as long as the piece hasn't been high temperature kiln dried, the oils will stay in the wood.
If you want to keep as much color as possible, use a marine spar varnish with UV inhibiters, but as any boat owner will tell you, varnish is a maintenance item.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Pjames
Thanks I will go with linseed oil don't mind reapplying every now and then
