Quick question
Started by Noobsawyer, May 09, 2014, 01:51:16 AM
Noobsawyer
How much clearance should there be on the rollers that contact the 2 rails that your head moves on ?
I can pick up on the moveable side of the saw housing and see like an 1/8 " of movement.
Seems like way to much.
Is the only adjustment for this the track roller adjustment ?
Any input will be helpfull,
Thanks, Pat
Chuck White
I don't have my book right here, but it tells you how close to the rail the roller is supposed to be.
Being able to lift the outer end of the sawhead 1/8" is normal.
