Need help locating parts
Started by Dewey, September 15, 2011, 01:31:08 PM
Dewey
I have a Timber Harvester Blade Sharpener ..  The little bearing that rides on the cam is gone  does anyone know where Timber Harvester Parts may be available ???  I'm heading now to Kaman  Bearings  to see what they may have
Brad_S.
Depending on when you bought it, early on TH simply rebranded Cook's sharpeners so you could get it directly from them.
Cooks may also be able to help you if it is an actual TH brand sharpener or you may want to contact Dave at our sponsor, CMS, as well.
Dewey
Thanks Brad....  It looks like I have one coming tommorrow....  It's good to know that Cooks may have parts  also  !
Read the number off the small sealed bearing and order from any good auto parts store or bearing supplier. Frank C.
Dewey
this bearing is pretty small and fell apart  when I unbolted it never thought to look for numbers.... I will do that next time thanks
