DIY Brush sander
Started by NateF350, September 10, 2019, 09:17:29 PM
NateF350
Hello, I'm Looking to make some distressed flooring for my house. I'd like to pony up for a supermaxx unit but it's not in the budget for a number of year. I've seen a couple homemade brush sanders but I can't find any details on what they use for brushes, motor speed or anything like that. Anyone make or using one?
low_48
Depends on species of wood and how extreme you want to distress it. I doubt if a sanding brush head would do much on hardwood, probably have to go to a wire brush drum. http://www.quickwood.com/abrasives/steel-brushes/
NateF350
Yes most have nylon and steel brush heads. The homemade ones were using steel brushes but it was hard to tell what type they was. At $1000 a head for the supermaxx ones there has to be better diy options I'll check out the link you provided thank you
Brad_bb
A less expensive option would be the Makita wheel brush sander wouldn't it?  I have 2 of them.  I have cleaned a lot of barnwood.
Ruffgear
I have no input on the brush sander. If you have planer you could sharpen irregular spots in blade to give you hand scaped look. Just an idea
Ljohnsaw
I'd bet that @tule peak timber would have some ideas and maybe some pictures of shop-built tools.
tule peak timber
I have to laugh....We just came up for a design on a rush job. I will post pics of the prototype tomorrow. Rob
Crusarius
hackberry jake
tule peak timber
Attached are pics of the prototype wire brush we developed last week for a rush job on the horizon.I can go into the thought process ( long litany ) but this works and allowed us to bid the job.Version 2.0 is next week with bearings and a power feeder. It is a wire brush and NOT how we typically distress.  Cheers Rob
Crusarius
Have any pictures of the end result?
tule peak timber
That will be next week when the bearings arrive. Previous pics were this morning.
NateF350
Quote from: tule peak timber on September 15, 2019, 12:19:10 PM
I thought about doing a setup just like this, the only thing I don't have is the wire brush. Care to share where you found that one? And I also would like to see the end results.    If this isn't how you typically distress, how do you distress?
tule peak timber
Solo Horton is where I've been buying the 4 inch arbor mount wire wheels.
  The best wire wheel cup I've found is the 6 inch Makita that mounts to a big angle grinder. Really heavy but will raise the grain in oak - no problem.
  We distress with lots of different tools in stepped sequence, and always with at least 3 people to prevent pattern forming. Lastly I critique and add a little this and that- always looking to break patterns.Once the distress is done a great deal of enhancement can be achieved with subtle coloration ( adding dirt and oxidation ) where it should be accumulated over time.
  The level of distress is different for each customer and the size of his pocket book :)
Southside
So you are trying to distress the lumber or the customer?  :D
btulloh
Those brushes are usually used to clean barn siding and such. You probably would be better off with some kind of flail for distressing. Just my two cents.
HM126
NateF350
Thank you tule peak, I'm going to order some brushes and give it a try. Those makita brushes ain't to cheap ether wow lol
tule peak timber
Nate we have not set up the arbor brush 2.0 because we don't have a signed contract on that particular job. I will post if we get the go-ahead.  Rob
tmbrcruiser
Thank you the pictures TPT. I have a similar need for a different reason. I air dried some cypress outside before it went to the kiln, now the lumber has some sticker stain, surface stain from rain and darkening from the sun. My customer wants the cypress as ship lapped paneling with a rough face. I've used an angle grinder with a cupped wire wheel to clean the face but that is very slow. Your plan will speed things up, thank you again!
Once you get sap in your veins, you will always have sawdust in your pockets.
tmbrcruiser
I just sent out an order of ship lapped cypress siding that the buyer wanted a rough finish on. I read the thread and built a similar setup. Made a few changes 5/8" thread all, put spacers between the wire wheels, two pillow bock bearings and angled the rods at about 45 degrees.
Also used two short pieces of 4"x4" screwed to a piece of plywood to mount pillow blocks on. Added the shop vac with the wide collector and pushed the boards in and out from the under side of the wire wheels. Thanks for the idea TPT.
tule peak timber
Super.....We still don't have the contract . Bought all the parts to set up like
tmbrcruiser, just waiting........
tule peak timber
I might have the contract next week so we set this up today.
Southside
Do you have a photo of the finished wood? I have a customer who asked about distressed flooring today.
samandothers
Quote from: tmbrcruiser on October 16, 2019, 04:20:17 AM
@tmbrcruiser did you take any pictures of the finished product you could post?
Tule Peak, nice set up.
tule peak timber
Quote from: Southside on October 29, 2019, 09:48:51 PM
I will post some pics when we get rolling. This setup is for VERY light wire brushing which is what the customer wanted.
