Cookies
Started by Good Feller, July 02, 2008, 06:46:47 PM
Good Feller
I'm wondering what cookies are?  NOT the kind you eat either.  I've heard of guys talking about using cookies for felling trees.  I guess it's some sort of a wedge?  So how do you make them and why do you use them?  If someone could draw a picture that would be great!  Thanks!
Good Feller
zackman1801
a cookie is just a thin section of a log once you cross cut it, so its essentialy a small little circle of wood, usually a few inches in thickness. some people insert them into the  the back of the cut to jack up the tree when wedges alone arent enough, ive never had to do it but i have enough wedges to to put most trees over.
"Improvise, Adapt, OVERCOME!"
Husky 365sp 20" bar
DR_Buck
And I thought this post was about food.  ;D
Woodhog
Another use is for filling in holes and bumps around rocks etc for your woods road.
They are flat and dont roll around under your wheels when you run over them..
We also call them washers....
After you get your wood out you can pick them up and burn them in your stove, they split up easy as they are not very  thick...
Ron Scott
On my last timber sale, the landowner had the logger saw him a couple large cookies about 5 inches thick from a large sentinel white pine tree on his property.
He is now having the local Amish woodworkers make them into tables as a sentimental remembrance from his long owned family property.
I also had a red pine trepass case where the judge required a number of cookies be brought into court as evidence of the trees growth and age. Cookies from trees can have a number of uses. ;)
~Ron
Onthesauk
"Cookies from trees can have a number of uses."
Here in the Northwest we cut cookies from western red ceder and use them for steps in the flower gardens.  Nice size, nice color.  Then, because of all our rain, they get a little moss on them and become slicker then ****.  You step on them, your feet go out from under you and you end up flat on your back!  Don't ask me how I know this.
John Deere 3038E
Sukuki LT-F500
Don't attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
Ron Scott
Yes, I've seen them used as patio blocks also. You need to wear your caulked boots. ;)
~Ron
Mr Mom
Thoese are not cookies there beaver biscuts....... ;D ;D ;D.
Thanks Alot Mr Mom
Phorester
Beaver biscuits... I like that better than calling them cookies.
TexasTimbers
In the right hands cookies become beautiful platters, plates, bowls, clocks, tables, and all manner of cool stuff.
Beaver biscuits. That there be neat. Beaver pancakes when they are really thin. Even thinner? Beaver crepes. ;D
PC-Urban-Sawyer
Quote from: TexasTimbers on July 04, 2008, 11:02:17 AM
Even thinner, Beaver crumbs  ::)
leweee
routestep
Cookies are a way of a website tagging your computer at home so that its easier for the website to find your computer. I think computer hackers also use cookies somehow to get into your computer. That's about all I know of cookies. I'm hungry now, off to the kitchen for a snack, hopefully with milk.
Phorester
I have two cookies - er, beaver biscuits - that I use in talks with youngsters.  One is about 13" diameter, the other one about 1" diameter.  They are both from 23 year old trees.  I use them to illustrate the difference in growth of trees in a managed forest versus an unmanaged forest.  Raises the eyebrows of adults too.
rebocardo
The problem of using cookies instead of wedges is they can break under the weight and the tree falls the wrong way.
I use cookies as wedges when cutting rounds, because that way when the cookie falls :-D  I do not feel bad when it hits the running chain, gets chewed up, or flies 15 feet into a pile of leaves.
I used wooden $0.01 cookies to get even bigger cookies, these $35.00 oak cookies I did yesterday are 5" thick by 37" diameter. I suspect they will eventually be called table tops :-D
rebo
The growth rate is pretty good on those 37" diam cross-sections (cookies?).
Phorester
Very pretty pattern Recarbo.
On cookies with a stain such as these, does that interfere with the adhesion of varnish or other coating you use on the completed table?
Dodgy Loner
Finishing shouldn't be a problem with those cookies.  The "stain" you refer to is what I call "heartwood" ;).  Looks like water oak to me.
Phorester
I'm seeing the heartwood as a distinct defined circle of dark brown wood in the center of the tree.  I'm refering to the light gray wavy edged wood, which I wonder is the beginnings of heartrot or another bacterial or fungal stain.
Or is this wavy edged circle how heartwood looks in water oak? Water oak is pretty much nonexistant up here, and even at that I've never seen the inside of one before.   ;D
thedeeredude
Our pin oak looks like that a lot.
rebocardo
Yes, on the rough cut boards 32"x32"x5" it shows up. I do not know exactly what it had, but, it had mushrooms and other fungus growing from under the bark. It certainly smells, my wife asked what the horrible smell was from the garage and I told her it was money  :D
I am pretty sure it was water oak going by the book I.D..
