elevator
Started by rebel, September 28, 2014, 08:42:12 AM
rebel
next project convert to firewood elevator any suggestions thanks
lopet
Belt or chain ?     Electric or hydraulic ?
rebel
lopet
If you have a chain drive with paddles  make sure you have no sharp edges on the sides or wood will catch and stall it.
Also put your hydraulic motor at the end, so the chain pulls and you will have less problems.  You may have to run some extra hydraulic lines to the top , but if you use half inch water lines it's not that bad.  It looks like you have a good base , go for it. 8)
