Faces in a Table
Started by WDH, December 14, 2015, 08:47:44 PM
I built a farm table for my friend Larry's wife out of red oak.  She wanted it rustic.  I pulled out the boards and looked at several ways to match the grain, then noticed that there were several boards, if bookmatched, that showed a figure of what looked like a face to me.  The first one that I noticed was a sleepy Hoot Owl.
I kept experimenting, and found a sleepy Grinch.
The last one looked a bit like a monkey to me, or maybe a goldfish staring you in the face.
Here is a view of the completed table wet with the first coat of tung oil.  The sleepy Grinch is in the right foreground.
This was a 9 1/2 foot long table, 42" wide.  You can land a small plane on it.
pineywoods
Danny, I see some nice legs..Did you finally get yourself a lathe ? Nice  8)
POSTON WIDEHEAD
I love the Goldfish.  :D
Good job Danny.
The legs came from Osborne Wood Products in Toccoa, GA.  Sorry Wayne, no lathe  :)
Very nice.  Were the holes filled, and how?
Don't let Marty Parsons see it, or he will be trying to do a touch and go landing.   ;D
yukon cornelius
I love that table! I try to bookend every chance I get. When i point it out to customers and explain how it works they all seem to think its so neat. I also like looking for face type characteristics. Those little things make people fall even more in love with their new piece. I am not real familiar with tung oil but have been trying some here and there. I did a cutting board tonight with it. I think I need more polishing with it because it keeps looking dull. 4- coats and letting it soak in a long time before wiping off excess. I read it could use a polish with steel wool between coats to shine it.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Steel wool will leave very fine pieces of steel embedded in the fine pores of the wood.
I would use wet/dry very fine sandpaper to sand the surface while the oil is wet and before wiping off.
Getting a fine finish is a lot of hard hand work.
customsawyer
www.thecustomsawyer.com
Nice table and a nice touch with the book matching.
You southerners like big rugged heavy tables. ;D
lowpolyjoe
Mooseherder
Beautiful!
Please pass or slide over the Jelly. ;D
I did not fill the beetle tracks and beetle holes.  And, I did not fill small knot holes to add to the rustic character that she wanted.  I did fill the eye slits in the hoot owl and the Grinch by using walnut sanding dust and wood glue to make a dough.  I wanted the eye slits to be dark.  After they were sanded down, they turned out nice.
It was all Larry and I could do to get the table top into the house.  That thing weighed a bunch.  I told him that if he ever moved, he would have to leave the table with the house   :)
sandsawmill14
Dodgy Loner
I saw an alien where you saw an owl :D
Can't believe you still don't have a lathe. Nothing like getting all covered in shavings. Best part is when you're turning in shorts and get your shoes filled up ;)
mesquite buckeye
I'm betting that you can put your elbows on that table and not worry about annoying others with wiggling the drinks.
;D 8) 8) 8) 8) :snowball:
I like it. ;D
Jemclimber
Very nice table Danny!!!
Quote from: Dodgy Loner on December 15, 2015, 09:14:07 AM
If you turn in shorts you might as well be wearing sandals as well.  :D
lt15
mesquite buckeye
Those sandals are fine right up until that bunch of scorpions comes rolling out of the log. :-\ :snowball: :snowball: :snowball: :snowball:
You get scorpions in a log on the lathe ??
mesquite buckeye
Right before the log blows up. ;D
mesquite buckeye
We have very special logs.  ;D 8) 8) 8) :snowball:
Sometimes we get bees instead.
Or lizards.
Or black widows. :(
Dodgy Loner
Quote from: Jemclimber on December 15, 2015, 01:19:52 PM
Better make da#% sure you don't drop a gouge on your foot :o
Had a local turner in his 70's that got beat'n up by his lathe recently. The wood became a projectile. :-\
Quote from: Dodgy Loner on December 15, 2015, 03:33:03 PM
Dat must be Yooper talk for DanG   ;D
yukon cornelius
Quote from: mesquite buckeye on December 15, 2015, 03:02:35 PM
Or lizards.
Or black widows. :(
You are not alone. nothing better than putting a log on the mill and getting scorpion stung just as you reach under to flip it around. Or a lizard running up your leg, or copperheads rolling out of hollows.
