Whiskey Barrel Coffee Table
Started by Bill Gaiche, December 19, 2015, 07:42:09 PM
Bill Gaiche
I have seen these and thought they were pretty cool and I wanted to make one. So I was able to purchase a 30 gallon whiskey barrel. Smaller than the ones I had seen but what the heck, smaller might be ok. It wasn't going to be for myself anyway. It has a Walnut base and top. Finished with lacquer finish.
lowpolyjoe
Ljohnsaw
Beautiful, Hard to tell from the pictures, is that coffee table height or is it a dinning table?  Are you going to make another out of the other half?
John Sawicky
Bill Gaiche
John, its 18" heigh. 34" wide x 25" deep. bg
POSTON WIDEHEAD
samandothers
Saw the first picture and thought that it was cool but wanted to see the char in the white oak.  Thought man that would be cool with glass on top but the top you put on it was really nice.  Then saw the pic with the piano hinge and the view of the char and it was so nice.  Great job!
Bill, your projects are always "over the top", and this is no exception.  Very Nice.   smiley_thumbsup
21incher
That is a really nice job. That is some pretty walnut you selected for the top. 8)
Red Good
Stihl 211C saw
Massey 135 deisel tractor with a front loader
Can Am 800 max quad
2001 Chev S10 pick me up
Home made log arch
cbla
kettlekorn
Very nice and unique.  Another outstanding project from members of this forum.
EZ Boardwalk Jr , Kubota L3800,  250 acre farm
Ran across this article by James Broyhill.. other things from old barrels.
http://www.woodworkersjournal.com/james-broyhill/
Woodey
Nice Whiskey Barrel Coffee Table. :)
That is on my bucket list of items to build.
WOODMIZER LT40HDD34CAT w/accuset
JLG SKYTRAK 6036 Telescopic Forklift
NYLE L200 KILN
BAKER M412 MOULDER
Dave H.
nice! i bet it still smells good too!
Ljohnsaw
No one else asked, so...  I've never seen the inside of a charred barrel before.  What are the parallel "clean" lines and the checkerboard area, what's with that? ???
John Sawicky
Bill Gaiche
I am not sure about all the inside. I believe that with the holes and saw cuts, it allows for more contact area for the whiskey to do its thing. I am sure there is some brewers can help out on that question.
     It still had a very strong whiskey smell and the yellow jackets and nats like it. bg
Darrel
Wow! I never would have thought that you could make something so lovely starting with an old barrel!
1992 LT40HD
GAB
Bill:
Three questions:
Why did you use the portion of the barrel with the bung hole in it?
And what size barrel did you start with, diameter, height, and gallons?
How high is the table off of the floor?
TIA
Gerald
Ljohnsaw
Quote from: GAB on December 26, 2015, 12:05:40 PM
Bill:
Three questions:
TIA
Gerald
Quote from: Bill Gaiche on December 19, 2015, 07:42:09 PM
Quote from: Bill Gaiche on December 19, 2015, 10:12:49 PM
..., its 18" height. 34" wide x 25" deep. bg
Thirty gallon barrels are about 24" in diameter and with his table top overlap, he got his 25" wide.  The barrel is probably 32" long if the finished table is 34".  I think the bung hole just ended up there when he aligned the logo on the barrel end the way he wanted it to look - I would have done the same.  Plus, you can sweep out all the junk easier  ;)
John Sawicky
Bill Gaiche
GAB, 30 gal. Roughly 31 inches tall. 21.5 inches wide at widest point. Barrel Head is 18 inches. That hole is going to show in one of the two halves, so I chose it in this half. The next table will have no barrel bung. I sold it for $300.00 before I had it finished it. The same person wants the other half when I get around to making it. bg
GAB
Quote from: Bill Gaiche on December 29, 2015, 07:27:27 AM
Bill:
Thanks for the reply and I wish you and everyone on this forum a very prosperous and healthy New Year.  Now go and write 2016 for the year for the next 40 checks.  I also need to do that.
I also think you are giving your customer a very good deal price wise.
Just out of curiosity how did you cut the barrel?
Does someone supply hacksaw blades that will run in a sawmill?
I have sawed some 15 gallon plastic barrels with the mill. Just need to go slow.
Gerald
Bill Gaiche
Gab, I put a strap around the barrel first. Used a thin metal cutting grinding disc 1/16" on my grinder to cut the bands at the half way point. Before I cut it I added some screws thru the band ends near the cut so it would not come apart. After cutting the band, I released the strap. Then I removed the ends and sawed them in half on my cross slide compound miter saw. Then I started putting it all back together. bg
GAB
hackberry jake
