Putting together a 25995 under CDL single axle Log Truck.
Started by Ohio_Bill, October 25, 2016, 11:21:03 AM
Ohio_Bill
Had a chance to pick up this 2005 Int 4300 cab and chassis with 95000 miles on it.  So it will replace my 25 year old Ford CF7000 that has served me well. The Ford had a flat bed so I added bolt on bunks. This one will have a regular log bed. My Son-in-law and I were able to get a lot of the bed built last weekend. The bed should weigh about 1900 lbs and should bring the truck in at about 11000 lbs.
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
BargeMonkey
 Nice looking job, be a handy sized truck. About 1800bdft to a load ? We built a truck about 5yrs ago and you can make a nice truck for 1/2 what they want for one up in NY.
Ox
Hydraulic brakes?  If I remember right, something with air brakes requires a CDL, right?  No matter the GVW?
ohiowoodchuck
No cdl required as long as it's under 26,001 pounds. If you pull a 1 ton truck with a 10 ton trailer and hauling commercially you will need a cdl. This combination doesn't have air brakes. I use a one ton and a dual tandem trailer and no cdl but I fall into the farmer and 150 miles from home.
Education is the best defense against the media.
Ohio_Bill
The new truck does have hydraulic brakes. They are disk all the way around. The CF 7000 has air brakes.  Both trucks are under 26001.
As I understand the Regs and have been assured by the PUCO, which is the DOT in Ohio. No CDL required if truck is under 26001 and is not pulling a trailer with a GVW of more than 10000. If you fall into that category, breaking system does not matter.
Bill
repmma
The trailer can be over 10k lbs you just can't exceed 26000lbs combined.  In Maine at least, but I thought this was all federally established and therefore the same?
Thomas 8020, Timberjack 225C, Ford 5030 with Norse 450 winch, stihl saws and 142 acres to manage.
Jdwoody
Quote from: repmma on October 25, 2016, 09:11:26 PM
Federal Dot laws state that the cdl becomes necessary at 26001 on the truck or 10001 on the trailer. Not 26001 combined. You can pull a 10k gvw trailer with a 26k gvw truck. You cannot however pull a 10001 gvw trailer without a cdl. Even if you pull it with a Ford Ranger and the trailer is empty. I spent out a little north of $1700 on this mistake last year. I was pulling my 14k trailer with my F250 with a gvw of 8600. I was loaded only with my stump grinder which weighs in at 1200.
06 Asv Rc 100
03 Bobcat 322
94 f350 Winch Truck
Stihl MS 260
Husky 394 Xp
Alaskan Mill (hope to change this soon!)
Brian_Rhoad
Jdwoody
Quote from: Brian_Rhoad on October 25, 2016, 10:58:39 PM
You don't need a CDL for a trailer over 10000 pounds everywhere.
https://forestryforum.com/gallery/albums/userpics/10136/2836/Scan2.jpg?easyrotate_cache=1272943045
State laws do vary, a lot in some places, however the federal law goes beyond the state. If the officer is aware of the fed regulations, and he so desires, he can legally ticket you. That document is also circa 1986 so I'm not sure if it is still valid. Most officers are fair and reasonable as long as you are but every area has that one guy whom everyone in business knows. I know the one here pulls me in every chance he gets. He never finds anything to ticket me with but always promises to get me next time. Side benefit is my equipment is in excellent shape due to it!
06 Asv Rc 100
03 Bobcat 322
94 f350 Winch Truck
Stihl MS 260
Husky 394 Xp
Jdwoody
By the way to the OP that "log truck" is very nice. Looks like it will be a great rig. What engine and tranny does it have?
06 Asv Rc 100
03 Bobcat 322
94 f350 Winch Truck
Stihl MS 260
Husky 394 Xp
Brian_Rhoad
This is from the Federal CDL Manual.
You must have a CDL to operate:
Any single vehicle with a gross vehicle weight
rating (GVWR) of 26,001 pounds or more.
A combination vehicle with a gross combination
weight rating of 26,001 or more pounds, if the
trailer(s) has a GVWR of 10,001 or more pounds.
A vehicle designed to transport 16 or more
passengers (including the driver).
Any size vehicle which requires hazardous
material placards or is carrying material listed as
a select agent or toxin in 42 CFR part 73.
Federal regulations through the Department of
Homeland Security require a background check
and fingerprinting for the Hazardous Materials
endorsement. Contact your local department of
driver licensing for more information.
ohiowoodchuck
Quote from: Jdwoody on October 25, 2016, 10:50:25 PM
that's strange must be a state thing. A lot of the utility companies around here have class b cdl. Say they drive the large digger truck that weighs 46,000 but pull the pole trailer which weighs around 4,000. You only need a class b for that one since the trailer isn't over 10,001. I pulled a 14,000 lb gooseneck with a one ton dodge which was 11,200 and I was still under the 26k. I didn't need a cdl.
Ohio_Bill
Quote from: Jdwoody on October 25, 2016, 11:52:56 PM
Both trucks have the same transmission. Eaton 6 speed. The International has a 225 hp DT 466   and the Ford has a 170 hp 6.6 ford engine.
Bill
Jdwoody
I really like the 466 and the other variants. I've been looking for a single axle international with a 530 manual pump for awhile. Seem to be fairly rare.
06 Asv Rc 100
03 Bobcat 322
94 f350 Winch Truck
Stihl MS 260
Husky 394 Xp
tantoy
1968 Garrett 20 Skidder
1991 Ford 1920 Tractor/Loader
2000 Takeuchi tb135 Excavator
Stihl 020, 041 Super, 084
Husqvarna 61, 181SE, 357XP
Ohio_Bill
Wow you have a good eye. It is 6 by 6 .250.  Bunks are 60 inches high. Will be adding gussets. They are cutout just not installed yet .
Bill
starmac
There are two seperate loggers here, well actually one as one is shutting down his operation, that uses similar trucks. They have them setup to dump. The one does most of his skidding and all of his loading with a bobcat and moves a suprising amount of wood. With the dump he has fast turn around times.
g_man
Quote from: starmac on October 26, 2016, 05:16:07 PM
Are there any problems dumping with bunks ? Right now I use a standard dump body (smooth sided). I can haul small loads into the mill w/o being in the way, dump them quickly, and be gone. Don't bother or wait for the  loader/scaler who is usually busy with a big load. I was thinking of converting it to bunks but wondered how it would dump.
gg
Ohio_Bill
I have a friend with a flat bed dump with bunks. He loads with small end of log forward. He has damaged the bunks a couple times with logs catching when dumping. He dumps a lot of firewood logs and some saw logs.
Bill
g_man
Thanks Bill - I wondered about that. BTW that is a super nice truck you are building !!
gg
mills
It will work, but it's rough on the bunks. I'll dump a load several times a year, and no matter how you think you loaded it, knots and butt flares catch on the bunks and cross beams.
starmac
It must not be too much problems dumping with bunks, as the guys I know haul several loads a day, day in and day out. When one of them was just hauling to his mill yard, his turn around times were less than an hour.
Ohio_Bill
Making some progress on the truck . Did a test fit and making the bumper / hitch today . Should be ready for paint this week .
Bill
Dakota
Dave Rinker
Oliver05262
  Bill, do your stakes have a cap on top? If not, do they have a way to drain rainwater out so they don't freeze and split?
  Most I have seen around here that are made with box tubing have the stakes open on both ends (handy to hang the straps/chains on) and the bunk is butt welded to them.
Oliver Durand
"You can't do wrong by doing good"
It's OK to cry.
I never did say goodby to my invisible friend.
"I woke up still not dead again today" Willy
Don't use force-get a bigger hammer.
