Stopping the LT 15 Mast from falling off in reverse.
Started by 1Cross1WayLT15, September 02, 2016, 02:06:02 PM
1Cross1WayLT15
LT15 - after I finish a cut and start the Head in reverse ...what keeps it from falling off the end of the rail if I hold it in reverse a fraction too long? Is there a STOP?? That I haven't seen or mounted on the rail. If NOT, what do some of you do to make sure that disaster doesn't happen?
Thank you!
Rookie -
WM LT15 (w/ Power Feed).
stanwelch
Yes there needs to be a stop. I made a stop using a 2" piece of flat steel. Drill a bolt hole and used one of the existing bolts on the rail.
I am not home until next week. I'll post a picture after I return
Woodworker, Woodmizer LT15, Stihl 026, MS261CM and 460 chainsaws, John Deere 5410 Tractor 540 Loader,Forks & Grapple, Econoline 6 ton tilt bed trailer
kng
I thought the bracket that holds the rope is the stop?
2015 LT15G19 with Power Feed and custom trailer
Ox
I'm trying to wrap my head around why a high end manufacturer would send a mill out the door without a stop at both ends of a mill.  ???
stanwelch
MartyParsons
Hello,
The rope bracket stops the head from going any further.
Or are you talking about the idle side track bearing running off the bed rail?
I did see one bearing installed incorrectly from the factory. All you need to do is check the assembly picture in your parts book.
If you need more help pm me.
Marty
