Entry deck/Bridge replacement
Started by Planman1954, October 30, 2015, 07:30:28 PM
Planman1954
I thought tonight would be a good time to post some photos of a project I just completed for my home. I began to notice some rot and sagging on the arched entry bridge that leads to my front door. Something had to be done now!
I happened to run across some old photos of the original bridge before I began removing it:
I began by removing the old bridge, piece by piece, trying to salvage whatever I could to reuse. Here's a photo of the bridge removed:
After the bridge was removed, I took the time to place 3 new support piers under the main entry deck which had sagged over time. I used my hydraulic jack and lifted the structure. It was a little nerve racking...watching for snakes and other undesirables! Here's a photo of the piers:
As you can see in the photo above of the removed deck, rot had occurred on the area between the deck and the bridge. I removed the old trim board which revealed the rot had entered the support posts! I decided to recess a treated piece into a notched out area in each of the four deck posts. The neat thing about this is that the rot was almost totally eliminated when the notches were cut. Here's a photo of the new 2x8 treated board set into the notched columns:
It was now time to set the main support joists for the new bridge/walkway. I used treated lumber to avoid the rot problem from happening again, but wanted to reuse the cypress where I could. Here's a photo of the joists being set:
You can see one of the new columns set in place. I notched them to rest flush on the outside joists. This makes them extremely sturdy. I also braced around all four new bridge posts.
Next I placed the decking onto the joists. I reused as many of the original pieces that were not rotted, and made the remainder from the original curved support joists from the bottom of the old bridge. Here's a photo of the decking in place:
The final step was to make the railing that needed to match the original arts and crafts design of the deck area. Here's a photo of the final product:
I'm glad it's finished! I worked off and on over a couple of weeks to do the job, with probably around twenty hours. It took less than $200.00 in materials...nails and treated lumber, to complete it.
I really love not having to walk over that arched area! That got old fast when it was first done years ago. Now I feel safe when my 84 year old mother comes to visit!
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
pineywoods
 smiley_thumbsup smiley_thumbsup . good job, now back to the millshed ...
Planman1954
lowpolyjoe
Nice.  I really like the unique looking railing  :)
POSTON WIDEHEAD
